$150 For A Recharge On A/c At Nissan?
Took it there today, asking $150 +tax to charge my ac to see if it just needs a recharge or leaks. I said no thanks. Cheapest I found a place to recharge is $85. Is that the normal rate? Any cheaper? I'm on long island.
yea my uncle has a shop and he charges $65, but repair shop chains charge around $90 and up, come by my house and bring the $5 can of freon and i got the gauges and ill do it for $30 lol and they wanted more on ur 89 max because it uses R-12 freon which is like $40-50 a can and in most states you have to have a license to buy it, luckily I have a license
if there is a leak, then its a PITA, and you have to mark it w/ dye and what not.
If its just a recharge, its not too bad to DIY. I did it once. The box even came with an instructional DVD video (lol), and a guage too to monitor pressure.
Get it done at Nissan, end of story. If the refidgerant is no loaded to factory spec, you WILL experience problems with the A/C. The refridgerant is added as based upon mass...so unless you have a certified scale to properly load it, I would not recommend it. I agree for shopping around for 95% of maint. work...this would fall under the 5% where I would take it to no one but a Nissan tech.
...so he is probably right!
Your A/C leaking? If you just want a recharge, just get the adaptor hose at Autozone and about two cans of R134A, attach hose to LOW pressure outlet which is left side of motor. Should be a blue cap. Dealers, shops, always charge an arm and a leg to put in dye. If you are getting hot air, listen for your AC compressor to turn on, if it doesn't, could be low 134 or bad compressor.
How do you know if its leaking? Also, when I turn a/c on.....i dont hear anything change in the hood, or sound like anything kicking up. It just sounds regular.
btw, Pep Boys by me has the a/c recharge for $99. I think.. haven't been there in a while though.
Andy
Ok the fan does not turn on at all when I put my a/c on. No cold air. Dammm what the heck!!
Does the fan have to come on instantly? Or wait a couple mins? I hear a click, buts its a light click.
So I had my friend look at my a/c. Since he knows a lot about cars, he actually told me that I have no leaks, and that all I need is a charge. However, my fans still don't not turn on when a/c is put on. Then again, the fan comes on after 5 mins to cool the engin.
the fans should go on right when you turn the ac on.. and go off if not needed. the $150.00 charge is a little high but it is ok..... you should take it to a free check up and go from there...
if you are short on refrigerant, or even have too much, the compressor clutch will not engage, therefore you will not have cold air. there are sensors, and i believe it is right after the condenser on the cooled side. if you have a leak, it could be a minor leak that you can't really tell, and takes time for your refrigerant to escape your system.
We charge 1 hour plus supplies for an ac recharge. = About $150
Originally Posted by aw89maxSE
I always thought it was a lot more. They wanted quite abite to do mine on my 89 max. I don't about the 2k AC system, but that seems reasonable, but then again, i'm not sure
Keep in mind an "ASE certified shop" doesn't mean jack. There are 7 ASE tests. Passing only one makes you "ASE certified". That doesn't necessarily mean that they are A/C ASE certified. Finding an ASE certified tech in A/C or an ASE Master tech is always a good idea (or a dealership), IMO.
Do you hear a 'click' when you turn the A/C on? If not, chances are good your compressor is shot. You can likley pick one up from a jukyard for about $50 - $100. Installation is not the easiest in the world, only due to its location.
It's a good idea to put a new oriface in if you have to open the system. Also remember IF you have a bad compressor that you should take it somewhere to get it recharged after swapping the compressor.
Condensation can get in there if you open the system.. water = bad pressure readings, different boiling points for the freeon, more wear and tear on all lubricated components, etc, etc.....
A 28 in.hg. vacuum needs to be put on the system before recharging.
First check power to the compressor..
If you have a multimeter hook it to the two wires at the compressor. Have someone turn your A/C on. It should get 12V to the compressor.
If you're getting 12+ volts and the clutch isn't engaging then you have a bad compressor. IF you're not getting any power to the compressor your problem lies elsewhere.
If the "light click" you hear is the A/c clutch the nest thing I would do is go to harbor freight and pick up a nice $50 set of gauges. (These look EXACTLY like the ones the trucks sell for $150-$200.)
Check your high/low side pressure make they are w/n specs.
