can you clean O2 sensor or must change?
Originally Posted by super6
i heard you can clean an o2 sensor with brake cleaner if it goes bad, can you do that or you have to change it? thanx.
the o2 sensor must be replaced....you can clean other sensors however...i know the MAF can be cleaned...don't worry too much about o2 sensors...well, it depends on which one goes bad....if your secondary one is bad, don't worry cuz it won't effect anything except throw an annoying SES....if your primary goes bad, it will revert to secondary as back up...so your good to go there...however, if your secondary is bad as well, then your gas mileage will suck...
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
RealityCheck
Aug 5, 2015 06:18 AM
