Rear Squealing Noise
Old Jul 4, 2006 | 06:50 PM
kidkay's Avatar
I have a problem that just recently occurred with my max. When pulling out of the driveway in reverse, there is loud squealing noise coming from the back wheels. Also, while I'm driving I hear the squealing for a short duration, then goes away. I'm not applying my brakes. I pinpointed the noise to my rear right wheel. From my forum search, the problems could be my e-brake cables, brakes pads, or brake caliper piston. Has anyone experienced the rear squealing? If so, what was the cause?
Note: I had my rotor resurfaced two months ago, but did not change the pads.
Old Jul 10, 2006 | 06:41 PM
kidkay's Avatar
bump
Old Jul 10, 2006 | 07:19 PM
3D2kMax's Avatar
squeaking noise
I am having the save problem but in the front wheel. It goes away when i apply the brakes. squeaking is there in either direction. i noticed that if i apply some WD40 to the area where the pads and the unit that holds the pad, it goes away but will come back. i try applying the breakpad quiter spray but still no good, thinking maybe it is the plates that sit between the pad and the holding unit. that is my guess, if i have a solution, will post it. please do the same.
Jack
Old Jul 11, 2006 | 06:15 AM
kidkay's Avatar
Yea, thx for the reply. I saw ur earlier thread you created and the response from MaxBoost925. I was considerding changing my rotors and brake pads as well, but I want to pin point what the problem is . I mite just settle and take the Max to Nissan and have them charge me just to look at it...arrrgghhhh.
Old Jul 11, 2006 | 06:23 AM
Progress's Avatar
It's business time.
It's probably a frozen caliper. They go quite frequently on the 5th gen.
Old Jul 11, 2006 | 10:52 AM
kidkay's Avatar
Thanks for the input, Progress, i'm doing some research on caliper.
Old Jul 11, 2006 | 06:32 PM
Progress's Avatar
It's business time.
Let us know what you find.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
doctorpullit
Sep 10, 2015 06:33 PM
ef9
Sep 5, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
