climate control light went out need help
Old Jul 5, 2006 | 07:56 PM
krmaxima's Avatar
well after i put in my system the left side of the climate control does not light up. i have the digital one. is there a way to replace these bulbs??? what do i need to do? its killing me well let me know
thanks
Old Jul 6, 2006 | 12:02 PM
krmaxima's Avatar
no one as replaced a bulb????
Old Jul 6, 2006 | 12:25 PM
upstatemax's Avatar
Dealers sell the bulbs, if you know how to take off the trim to replace the radio the CC is easy as cake.
All you have to do is pull the CC and find the bulbs, it is really easy and not much to explain. I would change them all at once though, I think there is four in there.
Before someone chimes in with "just change to LED's", I dont like how bright they are and it is way more work than what I want to do when you can get all four direct replacements for under $20.
Old Jul 6, 2006 | 01:02 PM
AceofSpds's Avatar
wat
Sometimes whenever you mess with the headunits n climate controll, they decide to get loose, and i guess they dont make a good connection not light up, try pushing on the peice and it should light up, if not your bulbs are burnt.
Old Jul 6, 2006 | 06:45 PM
krmaxima's Avatar
does anyone know the part number because i went to the dealer and they dont know.
thanks
Old Jul 7, 2006 | 05:13 AM
upstatemax's Avatar
thanks
I might be able to PM/post it to you this weekend... I might have an extra in my car.
Old Jul 7, 2006 | 12:14 PM
krmaxima's Avatar
thank you so much
Old Jul 9, 2006 | 08:11 AM
upstatemax's Avatar
thank you so much
I cannot find the bulb or the paper work from the dealer.... If you cannot find it still, I might be able to call my dealer because they found the part # in under a min...
Old Jul 9, 2006 | 02:37 PM
illlojik's Avatar
I C U
IF you do get the part number, I'd love if u shared this info with me too. auto climate control lights are off too. If I give it a good knock, they will come on but only on one side.
Old Jul 9, 2006 | 04:59 PM
MIXXMAX's Avatar
Yeah, for the digital climate control, there are like 4 bulbs in total. The dealer should have them. I bought some a couple of years ago. Sorry, I don't know the part number off hand. I'll try to look up my past receipts. When you go to the dealer, just find someone who knows how to look up part numbers. They always have people in there that don't know how to break down parts in schematics and search more thoroughly.
Old Jul 9, 2006 | 06:57 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
FELLAS, YOUR BULBS MAY NOT BE OUT AT ALL.
The bulbs have what's called a 'bayonet-style' mounting base. It simply scrwes in. 99% of the time, the bulb has not gone out, the base has simply been knocked loose. You can save yourself ALOT of time and trouble by simply testing the fit!
Three.
Old Jul 9, 2006 | 08:10 PM
upstatemax's Avatar
Three.
Mine were burnt out... I tried that first and nothing changed, so I put in new ones and the problem was fixed. Saying 99% of the time they are just loose is a bit of an exaggeration.
MikesChevelle
Mar 2, 2021 11:32 AM
dr3am
25
Oct 22, 2015 08:53 PM
asianstyle
Aug 24, 2015 08:29 PM
