TRANSMISSON PROBLEMS!!..help..
Originally Posted by soonerfan
did you not read all my posts? the TCM CAN NOT be - reset, reprogrammed, or reflashed
Once again... Then how on earth did they reprogram mine?
I watched the guy walk over to my car with the computer, go in and come back out in under 10min. After that, the car drove 100000000000x better, besides the coil problem.
my proof -
the service manual says you cant.
5 nissan techs told me it cant be done
Do you have the right filters w/ a MAF
Hey guys, saw that your talking about a possible MAF problem making your shifting a little off. I read a previous post about how even if you replace your MAF, you have to make sure you're running the correct air filter. If you guys have a K&N, or a FRAM... those filters let in stuff that the Nissan Filter won't, so might of messed up your newer MAF again.. check some of the MAF posts and you can see that a bad MAF can give your car:
crappy shifting
stalling problems
engine hesitation
rough idle on start
The do-it-yourself MAF sensor replacement is $90.
So read up and see if you're experiencing the same symptoms.
I'm replacing my MAF today (stalling and rough idle on start problems), and then I'm going to the Stealership for an air filter...
crappy shifting
stalling problems
engine hesitation
rough idle on start
Originally Posted by dafertilizer
I called the stealership, and they said they can reprogram the TCM, I made an appt for the end of next week, so well see what happens
Originally Posted by Cutler
They are basically taking your money for no reason, Dave Burnette(arguably the best Nissan parts man in the country) has confirmed that replacement is the fix and reprogramming isn't possible....
Thanks!
i keep trying to tell these people. i guess the fact that i went through this doesnt matter.
i answered that above..its seperate
right underneath the air bag control unit
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
