TRANSMISSON PROBLEMS!!..help..
Old Jul 9, 2006 | 07:12 PM
rob van dam's Avatar
When i accelerate really hard my transmission hesitates when shifting...soemtimes while its accelerating it also hesitates while the car is speeding up. what could be my problem???
i have 70k miles on my Automatic transmission...
Old Jul 9, 2006 | 07:27 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Is it between all gears or mainly from 1st to 2nd?
Old Jul 9, 2006 | 07:35 PM
shift_2kmaxima's Avatar
man i've had same problem....
it would hit that 4k rpm range...and it wouldnt shift at all,,,,,i would have to let go of the gas, and hit it again and it would shift
and this was from 1st to 2nd gear only.....
after a new MAF, the problem has been fixed man....it shifts so smooth rite now.....cant feel it....
but i might be wrong, u might not have the same problem...
good luck man
huso
Old Jul 9, 2006 | 07:44 PM
footballplyrdan's Avatar
I have the same problem. I can't figure out what is causing the problem though. I was pulling out onto a highway today and stepped on the gas hard, the car hesitated for a second and then kicked in. Hope you find the problem
Old Jul 9, 2006 | 07:53 PM
dafertilizer's Avatar
http://www.nissanhelp.com/Ownership/.../NTB00-039.htm
check this out, I have the same problem
Old Jul 9, 2006 | 08:10 PM
trigger005's Avatar
any1 do this TSB and successfully fix the hesitation problem
Old Jul 9, 2006 | 08:12 PM
good luck man
huso
this is EXACTLY the problem i am having...how much is a new MAF??
dafertilizer.......that procedure stated in your link seems very involved...i wonder how much that would cost if i went to the dealer?...hmmmm
Old Jul 9, 2006 | 08:15 PM
SoonerFan's Avatar
Cletus
i replaced my TCM (per the TSB) on my 00 and it fixed the problem
Old Jul 9, 2006 | 08:19 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
Have you tried a Tranny flush? at about 65k my trans fluid was the color of chocolate, and i noticed a wonderful improvement after they put in fresh stuff.
Old Jul 9, 2006 | 08:25 PM
I did a tranny flush about 10k miles ago....
Old Jul 9, 2006 | 08:29 PM
upstatemax's Avatar
My hesitation problems were a combination of my TCM and Blown coils...
I had the TCM fixed and it still had a hesitation when I went to accelerate and it was the coils. Replaced the coils and it was good as new.
Old Jul 9, 2006 | 08:34 PM
how much did it cost to have the tcm fixed??...how about the coils?..thanks
Old Jul 9, 2006 | 08:36 PM
upstatemax's Avatar
Both were covered under my extended warranty...
Old Jul 9, 2006 | 09:06 PM
SoonerFan's Avatar
Cletus
you have to buy a new TCM.
around $400 for the 00 one
around $600 for the upgraded 01 that fixed the problem
Old Jul 9, 2006 | 09:10 PM
upstatemax's Avatar
Not to start a pissing match again but:
I was told by my dealer and from Nissan of North America they just had to reprogram the TCM and they charged my Extended Warranty $90...
That was done 60,000 miles ago and it has been fine since.
Old Jul 9, 2006 | 09:12 PM
SoonerFan's Avatar
Cletus
havent we argued about this before?
according to the service manual, it cant be reprogramed
Old Jul 9, 2006 | 09:22 PM
upstatemax's Avatar
Yes we have, but according to Nissan and the Lit for the Consult II it can be done...
Also the fact that they did it to my car in 15 min convinces me also.
Old Jul 10, 2006 | 07:17 AM
9DTALON's Avatar
If anyone needs the solenoid assy that is listed in the above bulletin, I have one for sale. It was installed on a car for all of an hour, and did not fix this specific car's problem. If anyone wants it, I am selling it for 75$ shipped in original box. New it lists at 385$.
Old Jul 10, 2006 | 09:43 AM
didnt I send you a PM about this? What ended up being the problem?
I am pretty convinced that my tranny is shot, and dont think replacing this solenoid will fix it (but what do I know)
Soonerfan - so you paid $600 for the upgraded TCM? and was that installed?
I just really don't want to have to put out $600 for a new TCM or the valve solenoid, and have to end up replacing the tranny anyway
Old Jul 10, 2006 | 12:17 PM
Love_00_Max's Avatar
In this URL, the solenoid valve assembly is clearly documented but then what is the TCM.
Is the TCM different from the soleniods?
Old Jul 10, 2006 | 12:28 PM
SoonerFan's Avatar
Cletus
it talks about the TCM (tranny control module). its the computer that actually tells the tranny when to shift. it gets thousands of signals from the ECU and compares them to stored parameters. then it sends a electrical signal to the solenoids which go in or out to shift the tranny.
the problem is caused when the TCM has problems proccesing the inputs. it takes it a few seconds longer to figure out that the tranny needs to shift.
Old Jul 10, 2006 | 12:33 PM
SoonerFan's Avatar
Cletus
i actually got the tranny replaced under warranty. it went bad because of the bad TCM (which i didnt know and i guess the dealership didnt either). the dealership didnt replace the TCM and about 5,000 miles later the problem came back and i replaced the TCM.
the list price on the upgraded TCM (31036-4Y960) is actually over $700. i got it from daveb for around $600 and installed it myself.
Old Jul 10, 2006 | 12:38 PM
it talks about the TCM (tranny control module). its the computer that actually tells the tranny when to shift. the problem is caused when the TCM has problems proccesing the inputs. it takes it a few seconds longer to figure out that the tranny needs to shift.
Couple of questions:
1) Is the TCM part of the ECM itself or it is some standalone module talking to the ECM?
2) Since my car was manufactured in 04/99, with the TSB clearly applicable to my car, how much damage has been done with slower shifting over the last 6 years?
3) Is it worth replacing when I have become so used to the slow shifts and 1->2 gear bang.
Old Jul 10, 2006 | 12:59 PM
SoonerFan's Avatar
Cletus
its a stand alone system that talks to the ECU. the tranny already has some damage...dont know how much
Old Jul 10, 2006 | 01:06 PM
oh my...this is going to cost me a lot fo money. what are some signs that your transmission is going out?...
Old Jul 10, 2006 | 01:08 PM
Feel sad to hear that my tranny would one day die inspite of feeding a rich cocktail of boutique fluids and above all being nice to it over the last 6 years, no hard shifting at all!!!
TSB is essentially for something that is manufacturer fault but then "not replicable" consistently. But if it is documented in the TSB that all vehicles before Sep,2000 then is should have been a recall, WTF should I have to have my tranny die due to a faulty part.
Old Jul 10, 2006 | 01:59 PM
larsony's Avatar
Before spending a crapload of money, read this thread:
http://forums.maxima.org/showthread.php?t=398513
Like others have said, it could be your MAF sensor. Very common to go out around your mileage. I thought my tranny was toast until I read the above thread. I replaced the MAF and the tranny shifts perfectly now.
Old Jul 10, 2006 | 03:00 PM
Nice, so it sounds like I'm not only gonna need a Tranny, but also the TCM if I want to fix this.
Is the upgraded TCM in all of the 2001's? if so would it be possible to get one from a local junkyard and swap it in? I know the place by me has an 01 right now...
Old Jul 10, 2006 | 03:01 PM
Replaced my MAF like 10k miles ago
Old Jul 10, 2006 | 03:09 PM
SoonerFan's Avatar
Cletus
yes...all 01's. i just wanted to get a new one and avoid possibly getting another bad one
Old Jul 10, 2006 | 03:11 PM
soonerfan
Can you detail the location of the TCM and any tips on replacing the part, since you have replaced it on your vehicle? I will in the mean time look around for a bargain deal with the local junkyard for a 2K1 TCM
Old Jul 10, 2006 | 04:09 PM
SoonerFan's Avatar
Cletus
soonerfan
its behind the radio. its about the size of two packs of cards sitting next to eachother.
unplug the battery (if not, you will blow the new one)
remove old one
replace new one
connect battery
Old Jul 10, 2006 | 05:37 PM
Nice, gonna call up there tomorrow and see how much I can get it for...
Old Jul 10, 2006 | 06:23 PM
remove old one
replace new one
connect battery
You detailed the upgraded TCM (31036-4Y960).
I checked a few of the junkyards and they have 31036-4Y901, which I assume is the first cut of the 2K1 TCM.
The TCM you got from DaveB seems to have 4Y960 (I assume there were 60 revisions till date to the 2K1 model since then), I am not sure if I should spend the $600 and get the most uptodate 4Y960 and above or the bare minimum 4Y901.
Old Jul 10, 2006 | 06:27 PM
SoonerFan's Avatar
Cletus
dave told me the one i bought was the version that fixed the problem (31036-4Y960). thats all i know. and after i installed it, the shifts were perfect
Old Jul 10, 2006 | 06:33 PM
what kind of prices were you getting from the junkyards?
larsony's Avatar
I was referring to the OP's situation...
Old Jul 11, 2006 | 10:58 AM
hazardeyes's Avatar
oh my god i think thats the problem i have right now, i dont know if its my transmission or TCM, i dont want to bring it to nissan dealership they might wanna rape me and make me change my transmission, my car 128K
Old Jul 11, 2006 | 11:50 AM
$100-$250, there are many pieces within this range.
Check out this website http://www.car-part.com/
Old Jul 11, 2006 | 06:37 PM
I wonder if the TCM can just be reflashed with the consult II?
