Restrictor plate...
Old Jul 12, 2006 | 01:12 PM
beancooker's Avatar
Restrictor plate...
Has anyone other than maxboost removed their throttle body restrictor plate? If so, pros...cons...
Old Jul 12, 2006 | 02:19 PM
rmh3093's Avatar
Only gentoo powered Maxima!
yeah i took mine out but i still have a stock intake and exhaust so I dont see any difference at the moment.... it took minutes to take out
Old Jul 12, 2006 | 02:34 PM
ColdSHO's Avatar
mines out, lil more whistle but as far as i know of, no gain.
Old Jul 12, 2006 | 02:56 PM
SoonerFan's Avatar
Cletus
mine is out. i cant tell a diffirence (good or bad)
Old Jul 12, 2006 | 03:21 PM
MadMaxNH's Avatar
Fortuna Favet Fortibus
Giving the Red Dragon a little boost? We'll keep it on the down low...
Old Jul 12, 2006 | 03:29 PM
Progress's Avatar
It's business time.
How does one remove the restrictor plate?
Old Jul 12, 2006 | 03:36 PM
SoonerFan's Avatar
Cletus
you take it out
remove throttle body. the plate is between that and the intake manifold
Old Jul 12, 2006 | 03:46 PM
beancooker's Avatar
Originally Posted by soonerfan
you take it out
Old Jul 12, 2006 | 03:51 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
your 02 had the plate?
Old Jul 12, 2006 | 03:53 PM
SoonerFan's Avatar
Cletus
actually i dont know. i removed it on my old 00
Old Jul 12, 2006 | 03:54 PM
beancooker's Avatar
I took it out and what do you know, more whistle and no other big difference, maybe a little at the top end.
Old Jul 12, 2006 | 04:00 PM
sloppymax's Avatar
i have never seen a 3.5 with one, which is why i asked. i used that as part justification to remove mine.
Old Jul 12, 2006 | 04:04 PM
Progress's Avatar
It's business time.
That's what I meant. I didn't want to come off as even more naive.
Old Jul 12, 2006 | 04:19 PM
NmexMAX's Avatar
dot dot dot ...
3.5L = .........
Old Jul 12, 2006 | 05:07 PM
steven88's Avatar
Need A Light?
i took out my TB quite a few times on my 3.5L....and I don't see anything inbetween....
Old Jul 12, 2006 | 05:12 PM
NmexMAX's Avatar
dot dot dot ...
That's because there's nothing there.
SoonerFan's Avatar
Cletus
not even a gasket?!?!?
Old Jul 12, 2006 | 05:14 PM
steven88's Avatar
Need A Light?
okay you got me
Old Jul 12, 2006 | 05:22 PM
NmexMAX's Avatar
dot dot dot ...
THAT is the 02+ restrictor plate, I knew it had one.
Old Jul 12, 2006 | 05:26 PM
SoonerFan's Avatar
Cletus
remove it!!!!!
Old Jul 12, 2006 | 05:28 PM
NmexMAX's Avatar
dot dot dot ...
Use a phenolic spacer... just like the one for the LIM...
Old Jul 12, 2006 | 06:15 PM
irish44j's Avatar
retired moderator
STOP CALLING IT A RESTRICTOR PLATE!!! This is not NASCAR
Old Jul 12, 2006 | 06:21 PM
NmexMAX's Avatar
dot dot dot ...
It's a gasket .. 's
Maximas are NASCARs.. Mullets FTW.
Old Jul 12, 2006 | 06:23 PM
sloppymax's Avatar
just cause you turn right doesnt mean the rest of have to. fast actually has a non specific name for the part and it is smaller than the tb. part of it is flat like a plate so i guess the name fits. we could call it the restrictive flat on one side with a waterslide on the other side plate that chips and lets paint go into your engine plate.
Old Jul 12, 2006 | 06:27 PM
irish44j's Avatar
retired moderator
the problem with calling it a restrictor plate is that that infers that it is RESTRICTING something...and then people think...."well I don't want any restriction!" and remove it.
Calling it a restrictor plate infers that it is hurting performance and therefore should be removed...which is not true.
I realize it's semantics, but it's really just "part of the throttle body" and nothing more.
Old Jul 12, 2006 | 11:28 PM
MaxBoost925's Avatar
Drug Money
...ok,
so its a VORTEX GENERATOR
Old Jul 13, 2006 | 12:44 AM
Drug Money
oh you can definitely feel the 1-2 hp in the high end.
or perhaps it was the whistle that got me?
Old Jul 13, 2006 | 05:05 AM
sloppymax's Avatar
but since its smaller than the tb, by around 5-6mm if iirc, wouldnt you classify that as a restriction?
Old Jul 13, 2006 | 05:15 AM
Deckdout2's Avatar
Play with my balls
Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate Restrictor Plate
Ftw
Restrictor Plate
Old Jul 13, 2006 | 05:30 AM
Puppetmaster's Avatar
You can feel 1-2 hps gains? Your butt dyno must hyper-sensitive.
Ftw
Restrictor Plate
Ftw
Restrictor Plate
Ftw
Restrictor Plate
Ftw
Restrictor Plate
Ftw
Restrictor Plate
Old Jul 13, 2006 | 05:32 AM
Deckdout2's Avatar
Play with my balls
That damn maxima.org sticker was suppose to add a couple horses, but I think the coefficient drag on them is costing me some speed.
Old Jul 13, 2006 | 05:33 AM
Progress's Avatar
It's business time.
Do they sell aftermarket "restrictive flat on one side with a waterslide on the other side plate that chips and lets paint go into your engine plate"s?
Because, if so, I have no money to afford one.
Old Jul 13, 2006 | 05:34 AM
Progress's Avatar
It's business time.
The stickers adding HP routine just never gets old,
loser.
Old Jul 13, 2006 | 05:41 AM
Deckdout2's Avatar
Play with my balls
loser.
Don't make me karate chop you in the jugular.
Old Jul 13, 2006 | 05:48 AM
Progress's Avatar
It's business time.
That's fine. Bring it on. My jugular would counter attack to your bawls.
Old Jul 13, 2006 | 05:53 AM
Where Deckdout is, Progress follows... how predictable...
Old Jul 13, 2006 | 05:59 AM
Deckdout2's Avatar
Play with my balls
I'm on invisible too, I can't hide myself from any of you phools. I'm glad your right there to it up though. Thanks
Progress's Avatar
It's business time.
It's the reverse in "the other board."
Old Jul 13, 2006 | 06:00 AM
Deckdout2's Avatar
Play with my balls
That's a little homo don't you think?
