clutch on 5th gen
clutch on 5th gen
What is the oem clutch you guys have on the 5th gen? I did the dek swap but need the 5th gen clutch because the 4th gen one isnt as strong. Thanks, oh and will the 3.5 5th gen clutch fit? or no?
I know you aren't going to be able to use the 5.5 gen one because the springs that are normally located in the disc are located on the flywheel on the 3.5. The setup for any 00-01 max should work. If you are planning upgrades, just spend the money now and get a stronger aftermarket clutch.
Violator
09-09-2015 10:14 AM
