cattman b-pipe ticking
hey guys i have a cattman catback. when i turn off the car i can hear a constant ticking from the b-pipe, i assume because it is hot, but it jsut started ive had the catback for a while. its not in contact with any metal or other objects, is there something that could be causing this? thanks
i use to have the exact same problem...after i removed the rear crossbar, it went away completely...you can also see the crossbar being eaten away from the heat of the headers...
when you go under there, you will see the small rear cross bar...its after the resonated bpipe
KabirUTA13
19
10-17-2015 02:15 AM
ColdCananda
09-20-2015 10:45 PM
Greenmaxspeed
08-31-2015 09:06 PM
