02 Fog light install, bumper off or not?
Old Jul 27, 2006 | 07:49 AM
6spBlkMax's Avatar
Ok so my 02 has the GXE inserts in the fog light holes and I am about to install some oem style fog lights. I have searched and found the instructions for bulb replacement without taking the front bumper off. I am wondering if that is what i should do, or if it would be better to take off the front bumper??? And if so, where are the mounting points that i need find to remove it? Thank you in advance!
Old Jul 27, 2006 | 07:52 AM
Puppetmaster's Avatar
All I've had to do to remove/replace the fogs is to remove the splash guards, that's it, not the entire bumper. I'm assuming the wiring is already there so you won't have to make any new connections.
Old Jul 27, 2006 | 07:55 AM
ShIft_uR FacE's Avatar
^^^ What he said. You do not need to take off the bumper. Just take a look under and remove all tabs and screws that hold the splash guard in place.
Old Jul 27, 2006 | 07:57 AM
6spBlkMax's Avatar
Im assuming the wiring is there too. My car is a SE but the previous owner did cheap fix on the front bumper and didnt install new fog lights. Guess he bought a GXE bumper? The car has the foglights switch on the steering column so im hoping its all good. Im going to give it a shot, thanks.
Old Jul 27, 2006 | 07:59 AM
PoLo's Avatar
2-Wheelin it...
i'll do you one even easier. don't go from underneath. go from above. remove your headlights. the whole bumper are is exposed. you can remove the fogs, and do what you want. i'm not a fan of being on the floor and removing stuff. made it harder since the car is low. tons easier to remove the headlights.
Old Jul 27, 2006 | 08:20 AM
If your car is not dropped and you have the "SUV clearance", you should be fine fitting under the car unless your a fat fawk.
Old Jul 27, 2006 | 09:16 AM
PoLo's Avatar
2-Wheelin it...
i think it's moreso who wants to laydown. it's easier to do the job standing up.
try it and you'll see....that is all.
Old Jul 27, 2006 | 10:31 AM
jeepik's Avatar
definitely take the headlights off
so much more room to work with
ive dont it both ways, removing the headlights is the way to go
Old Jul 27, 2006 | 12:07 PM
........word.
Old Jul 27, 2006 | 12:09 PM
SEmy2K2go's Avatar
Go BUCKS!!!
There's a ton of room to work with by simply going from under the car. That is creating way too much work for yourself.
Old Jul 27, 2006 | 12:18 PM
jeepik's Avatar
try it, i felt the same way as you do, there is only 2 10mm bolts per headlight, and it literally take abotu 30 seconds to take the lights off
Old Jul 27, 2006 | 12:19 PM
PoLo's Avatar
2-Wheelin it...
no one believes until they try it.
it's like saying, if you had the capability, would you do your oil change under the car, or standing up, given you were able to access the filter with nothing in your way.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
