5th Gen / 5.5 Gen Header Thread
Old Apr 26, 2007 | 10:12 AM
  #161
Child_uv_KoRn's Avatar
Bad *** Newb
Originally Posted by knight_yyz
i have cattman 3.0 headers on my 3.5 because there was a miscommunication. I had to buy a plug for the egr valve. Ports are the same.
bty that is going to be freeking loud!!
hehe That's what I'm going for. I have all of these morons with crapstangs and junk cars like that around me with "exhausts". I'm fixing to make them all look like pansies
Old Apr 26, 2007 | 10:17 AM
  #162
Puppetmaster's Avatar
Originally Posted by MaxBoost925
Are you sure dude? Me and Steven88 both had bend it on our cars.
I'm pretty sure I'd remember having to intentionally bend a motor mount bracket, lol. Nope, didn't have to do it.
Old Apr 26, 2007 | 02:12 PM
  #163
steven88's Avatar
Need A Light?
thats weird...maybe you worked from the top and bottom? cuz we worked completely from the bottom of the car
Old Apr 27, 2007 | 07:25 AM
  #164
Yeah, we worked on the rear manifold from both top and bottom. Trust me, I remember because a certain unnamed person was afraid to get under the motor with the center member removed, so he was helping from top.
Old Apr 27, 2007 | 07:29 AM
  #165
NmexMAX's Avatar
dot dot dot ...
I worked 100% from the bottom. Had to tilt the engine sideways IBitsalreadysidewaysFWD.
Which means, it needed to be taken off mounts etc.
Old Apr 27, 2007 | 09:08 AM
  #166
03MAXTNR's Avatar
is there anyway the motor can fall out if the center member is removed?
Old Apr 27, 2007 | 09:28 AM
  #167
MaxBoost925's Avatar
Drug Money
No. Not if you leave the top mounts intact.
My motor was hanging by 1 motormount, I had to place a jack under it to keep it secured.
Old Apr 27, 2007 | 09:39 AM
  #168
No, there are 4 motor mounts; front, rear, left, and right. The removal of the center member only requires front and rear be removed, so the motor will remain in place via the two side mounts. You will be able to rock it back and forth (its not something I'd do for fun though) to move it around to get to the manifolds if necessary.
Some people play it safe by putting a jack or jack stand under the tranny, but as long as the side mounts are secure, you don't really need to.
Old Apr 27, 2007 | 03:40 PM
  #169
OOmaxSE's Avatar
For my header install, didn't bend any motor mounts. I completely took off the front and rear motor mounts on the cross member. Unless you guys are talking about 3.5L.
Old Apr 27, 2007 | 04:01 PM
  #170
huffdaddy2008's Avatar
We bent the mount brackets not the mounts themselves. 3.0 or 3.5, Maxboost and Blackbirdvq both have 3.0's and they had to bend their brackets.
Towards the middle of the write up.....http://forums.maxima.org/showthread.php?t=385360
Old Apr 27, 2007 | 04:25 PM
  #171
HotshotVQ35's Avatar
my crossmember never came off on my install..all done with removing the IM
Old Apr 27, 2007 | 06:04 PM
  #172
upstatemax's Avatar
I never had to bend mine, and I put on Hotshot and Cattmans...
Old Apr 27, 2007 | 08:36 PM
  #173
03MAXTNR's Avatar
This write up should definitely be at the front of the page. This answered all my questions that i may have posted earlier about the tools and etc. Thanks.
Old Apr 28, 2007 | 02:47 AM
  #174
hahaha thank Puppetmaster. Its on the first page. Its on Puppet's install tips then theres a link in there to Blackbird's write up, just wanted you to do your research so that YOU found it.
P.S. I heart tequila
Old Apr 28, 2007 | 05:24 AM
  #175
BlackBIRDVQ's Avatar
drag racing is for wussies
I didn't have to bend any motor mounts for my install. Once you remove the center member, you can tilt the motor backwards and will be able to reach the bolts on the rear header. Removing the IM will also help getting to the upper bolts from above.
There is a bracket that bolts up to the BACK side of the motor- it attaches to the block with 14mm bolts x 4. There is a 17mm bolt that goes through it AND the rear engine mount. In order to remove those 4 bolts you need to bend the RIBBED tab inside that bracket, use a large prybar to bend that and then get yourself a 14mm boxed end wrench to break those suckers loose. They should come out by hand if the engine doesn't have a million miles on it.
I always remove the cross member, it makes this job much easier than removing the intake manifold. You CAN reuse your stock exhaust manifold gaskets AT the head, they are metal- vs the cheap stuff that comes with your new headers that will eventually leak.
Old Apr 28, 2007 | 10:13 AM
  #176
NmexMAX's Avatar
dot dot dot ...
Cattmans gaskets are very nice. Metal.
Old May 4, 2007 | 05:33 PM
  #177
upstatemax's Avatar
That depends on what Generation the Cattmans are... Whoever supplied the headers (made them), supplied the gaskets.
Old May 4, 2007 | 06:26 PM
  #178
NmexMAX's Avatar
dot dot dot ...
If they were the first sets, there are no quality issues. Mine have been on for quite a while issue less.
Old May 4, 2007 | 06:33 PM
  #179
upstatemax's Avatar
Yeah, the first ones were supposed to be good, but the next batches were hit and miss I guess.
Old May 5, 2007 | 09:50 AM
  #180
Drug Money
According to what I heard:
Gen 1 = best, proven HP
Gen 2 = less hp, quality issues?
Gen 3 = not proven yet.
Old May 5, 2007 | 02:40 PM
  #181
knight_yyz's Avatar
Toolie
i didn't get any gaskets with my 3rd gen headers, used OEM's
Old May 7, 2007 | 09:17 AM
  #182
03MAXTNR's Avatar
I called the stealership for prices on oem gaskets for my header install and he said i needed a plenum gasket as well. I dont know what the heck hes talking about. Let me get this strait. will the stock oem gaskets on my car be ok to reuse. He quoted around 70 dollars for new gaskets and that seems pretty high. Can someone tell me what gaskets i need to make sure i have the right ones. are the supplied gaskets in the hotshot kit any good?
Old May 7, 2007 | 10:11 AM
  #183
Your stock gaskets will work. I and many others have used stock gaskets. As far as the plenum gasket, i dunno, i guess hes talking about the gaskets for the y pipe? but those should be provided, i know in my Cattmans they were. Call him back and figure out what plenum gasket hes talkin about cuz the gaskets for the manifolds def. arent plenum. Ya the gaskets provided by hotshot should be fine.
Old May 7, 2007 | 10:19 AM
  #184
The plenum gasket is what goes between the intake manifold lower collector and the intake manifold; you only need this if you are taking off the lower collector (and we usually loosely use the term intake manifold or IM around here to describe it). That being said, I didn't replace the plenum gasket when I did that. The Cattman headers that I bought came with copper gaskets for the exhaust manifolds, but if yours didn't, new OEM exhaust manifold gaskets are good enough.
I've heard that the Hotshot gaskets suck, so I wouldn't use those.
Old May 7, 2007 | 10:59 AM
  #185
03MAXTNR's Avatar
where can i get good gaskets that will fit the hotshot headers? if i cant figure this out them im going to have to cancel the install.
Old May 7, 2007 | 11:09 AM
  #186
Just use OEM gaskets or some high temp liquid gasket, available at any auto parts store.
Old May 7, 2007 | 11:59 AM
  #187
machinehead131's Avatar
The gaskets on there should be fine.
Old May 7, 2007 | 12:04 PM
  #188
03MAXTNR's Avatar
the ones im worried about are between the headers and the y pipe. My hotshot kit came with these 1/4 inch squishy gaskets. i want some metal ones.
Old May 7, 2007 | 04:16 PM
  #189
03MAXTNR's Avatar
has anyone had good luck with remflex gaskets.
Old May 7, 2007 | 06:48 PM
  #190
OOmaxSE's Avatar
I'm not sure, but I used the ones Hotshot provided... I feel like they're actually Remflex where it says "300% crush." They've been good so far.
Old May 14, 2007 | 09:13 AM
  #191
03MAXTNR's Avatar
I just installed my headers and id have to say that the install wasnt to bad. it took about 6.5 hours to complete. I did run into a problem with one rusted bolt. It was on the cat converter. i had to cut off the nut and bolt on each side and then drill it out. Other than that it wasnt bad. the headers did smoke a bit when i first started them up due to them being ceramic coated but it went away after they were cured. One thing i missed was the wot i had with just an intake and stock headers. Now that the headers are on, you loose some of the intake growl but gain a little tone in the cabin.
Im very impressed with the power gain, as i was able to hit third gear burning rubber with an auto from a dead stop.
Old May 15, 2007 | 03:38 PM
  #192
mine came with the same, no problems....
Old May 15, 2007 | 09:51 PM
  #193
Bad *** Newb
Just got my ssautochrome headers. The y-pipe is well constructed and clean. The headers are fairly good, some bits from welding got stuck inside a couple vents and it could've been ground down better in spots (I'll take care of that though). As long as the fitment is good, that's $273 well spent.
Old May 20, 2007 | 12:45 AM
  #194
GabWood's Avatar
Finally installed my HotShots today. They had been sitting in my garage for about a year, so I figured it was about time to install them. Everything went really smooth until I got to the cat bolts. One sheared off and the other one got rounded off because I was being stupid. So I had to drill them out and slap some new ones in. Started it up and sounded like everything was good. Haven't drove it yet cause it was pretty late when I got done. Total install time took me about 10 hours due to my stupidity, but eh, live and learn, right?
Old Jun 5, 2007 | 06:01 PM
  #195
Has anyone had clearance issues with the front primary o2 sensor hitting??
I am about to put the new front header in and it is hitting but will still bolt up.
Will this be alright?
Thanks.
Old Jun 6, 2007 | 06:21 AM
  #196
NmexMAX's Avatar
dot dot dot ...
Not with the Gen I Cattmans.
HS's o2 bung is in one of the primaries, not the collector itself, so IMO, I would relocate that bung into the collector. With that said, you may need to extend the primary o2 wire to that sensor for that bung.
Old Jun 6, 2007 | 06:52 AM
  #197
OOmaxSE's Avatar
How necessary is it to relocate to the collectors? It makes more sense to have it at the collectors to me, but I do know that the stock manifolds have o2 bungs at the primaries. It probably makes a difference in a performance aspect?
Old Jun 6, 2007 | 12:42 PM
  #198
I was wondering more based on clearance issues.
Old Jun 6, 2007 | 01:13 PM
  #199
OOmaxSE's Avatar
I relocated the front o2 sensor before installation. I knew and read about the clearance issues so I can't vouch. But many others have that issue. $50 to relocate and plug up the old bung at most shops.
Old Jun 6, 2007 | 01:58 PM
  #200
What do you do just sand off the coating where the bung is going to go and weld it on there?
Where exactly should i get mine welded?
