Splash Guard-Passenger Side
Old Aug 10, 2006 | 08:29 AM
bvenvert's Avatar
I have a 2003 Max SE that developed a rubbing sound out of the passenger side when I turned the wheel all the way to the left. Over the weekend I jacked up the car and pulled the wheel to find out that the splash guard on the passenger side was apparently busted and a large chunk of it was still attached to the car inside the wheel well. It appears that this guard is actually a lower motor splash guard that covers the oil filter and the crankshaft pulley. Do I need to replace this guard, since it covers the lower part of the motor, including the oil filter and pulley? It appears to keep water out of the engine compartment from inside the passenger side wheel well.
Anyone have this problem? Any idea how much this cover might cost? Do you suspect it will get broken again when I have my next oil change done?
Old Aug 10, 2006 | 10:32 AM
DAP's Avatar
DAP
I would replace it. It shouldn't be to expensive. I think the chances of it breaking again are rare. I suspect you took it to a shop to have your oil changed. Most likely was damaged then or the screws/bolts were not all returned.
Old Aug 10, 2006 | 10:37 AM
upstatemax's Avatar
Replace it...
You don't need road grime all over moving motor parts.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
sliptap
Sep 30, 2015 05:57 AM
Noela
Sep 26, 2015 08:22 AM
