Ugh, bad ABS Wheel Speed Sensors
Old Aug 12, 2006 | 04:21 PM
alpinestars™'s Avatar
THIS IS...
Well my ABS light came on the other day and my car was driving really poorly. So I took it in to the dealer to have it looked at. It turns out my car is in "Fail Safe Mode" which I guess is whats responsible for the ****ty acceleration and such. Anyways I had my service advisor call National Autocare which is my warranty company to see if the ABS Wheel Speed Sensors were covered. Of course not. So I went home with my car unrepaired. I just looked at my coverage brochure and it spells out ABS SENSOR"S" as in it covers more than one sensor. Am i getting F@cked over by National or what? Id rather save the 350.00 its going to cost to install them and just pay the 50.00 deductible...
Old Aug 12, 2006 | 04:47 PM
upstatemax's Avatar
My extended warranty paid for mine to be replaced.
Crappy acceleration should have nothing to do with your ABS sensor. One of mine is pulled out right now and my car performs the same except my ABS and TC is turned off. I also had both fronts broken before and it never hurt my acceleration.
If I were you I would call the warranty company myself and verify that it is not covered. I think you are getting fawked.
Old Aug 12, 2006 | 05:00 PM
THIS IS...
Yeah I already tried calling them but their hours suck *****. I will try again on Monday.
Old Aug 12, 2006 | 05:29 PM
carsarecool's Avatar
upstate, you have TC too? You have an SE right? i thought that was an option for both years, maybe i was mistaken, definetly have abs though, no tc for 5 speeds?
Old Aug 12, 2006 | 06:38 PM
THIS IS...
I also wanted to add that my "OD" light is flashing sometimes when I start my car. Not sure but is this a tranny issue?
Old Aug 12, 2006 | 07:07 PM
KCMC582's Avatar
i have a 5.5 gen auto, and when my ABS sensor(s) went out, when i started my car, the TCS, SLIP, and ABS lights would all turn on, and i would have some major issues braking. it was covered by my nissan ext. warranty, but i dont know about the one you have
Old Aug 12, 2006 | 07:20 PM
upstatemax's Avatar
I have a fully loaded auto 2000 SE. 5-speeds could not get TC, only on autos.
Old Aug 12, 2006 | 07:22 PM
upstatemax's Avatar
Get it on a computer... See what shows up.
Old Aug 12, 2006 | 08:08 PM
THIS IS...
HOLY ****. I just went out to my garage to get a soda and noticed my CV Joint on my drivers side is RIPPED. There is grease all over the inside of my rim. FU'CK
Old Aug 12, 2006 | 09:32 PM
trigger005's Avatar
yikes sounds like a bad nightmare man
Old Aug 13, 2006 | 12:58 AM
THIS IS...
Yeah, luckily my CV Boots are for sure covered.
Old Aug 13, 2006 | 12:03 PM
They are covered? Thats good, those can cause driveability problems, noise, rough driving but im not sure about the OD light. ABS i think so, maybe someone who knows more about it can chime in but i think the axles have a toothed ring around the outer CV boot that the ABS sensor gets its readings from, so if its all messed up or covered in grease, could be your problem
Old Aug 13, 2006 | 01:57 PM
NmexMAX's Avatar
dot dot dot ...
I raped my ABS sensor installing wheel spacers and new studs
Old Aug 13, 2006 | 02:07 PM
upstatemax's Avatar
Frist set- ripped apart by control arm when I slammed my car on D2's.
Brand new passangers- torn clean out by idiot at dealership when they installed my Stillen lip. Then to top it off, they pretend like nothing happened and hand me back my car with my dash lit up like a Christmas tree...
Old Aug 13, 2006 | 02:18 PM
NmexMAX's Avatar
dot dot dot ...
Competing for most dash lights on when driving...
Old Aug 13, 2006 | 02:47 PM
upstatemax's Avatar
You are on!
Ok: ABS, TC, Slip and last but certainly not least my CEL for my EGR.
Makes a grand total of four lights on right now.
anyone got me beat?
Old Aug 13, 2006 | 02:50 PM
NmexMAX's Avatar
dot dot dot ...
I hardly ever wear my seatbelt
Old Aug 13, 2006 | 03:09 PM
upstatemax's Avatar
Don't make me have to disable my airbags and drain my windshield washer fluid...
Old Aug 14, 2006 | 09:32 AM
THIS IS...
Took her back in today. Hopefully my sensors will be fixed this time...
Old Aug 14, 2006 | 11:42 AM
jvienneau's Avatar
Just curious how they come-up with $350 for a wheel sensor? They are about $100 and take two minutes to change.
Old Aug 14, 2006 | 11:52 AM
Colonel's Avatar
Old Fuddy Duddy
I dunno about the two minutes to change part. I pulled one out of a fourth gen (I assume they are the same) and it took me a while as it was frozen to the sides. No amount of penetrating oil helped. I eventually just torched it out.
mrc00l88
Jan 25, 2024 01:14 PM
AnsonJ
Jun 2, 2017 01:35 PM
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
25
Aug 28, 2015 10:15 AM
