Need help with changing brake pads
Old Aug 12, 2006 | 05:11 PM
DOM's Avatar
DOM
I am having trouble with the rear ones. The brake piston is too tight and I can't fit it on with my new pads. Is there a tool or different way of getting this brake piston back on with the new pads?
Old Aug 12, 2006 | 06:23 PM
kvk2003max's Avatar
You can get a tool like this http://www.sears.com/sr/javasr/produ...seBVCookie=Yes from Autozone for about $8. The rear caliper piston will screw back into the caliper. I had the same issue and the piston wouldn't stay in. Tried it a couple of times and ended up replacing the caliper.
Old Aug 13, 2006 | 12:18 PM
ODB's Avatar
ODB
You may find a big pair of pliers works better than that cube tool - it did for me anyway. Make sure the wheel spins freely once you get it all back together...
Old Aug 15, 2006 | 07:32 PM
NisTech's Avatar
you can even do it with the needle noze pliers.
I got the cube though
Old Aug 15, 2006 | 07:36 PM
SEmy2K2go's Avatar
Go BUCKS!!!
It may also be a frozen caliper if you're having that much of an issue getting the piston to collapse.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
