4th and 5th gen brakes similar?
Old Aug 14, 2006 | 07:55 PM
carsarecool's Avatar
I looked around but didnt find anything on this, i'm pretty sure the rear brakes, at least calipers are the same between 4th and 5th gens but are the fronts? I thought i also heard the fronts were the same from 95-01. Reason i'm asking is cause at my work we have 00-01 rotors for 73 a piece and 4th gens for 27.99, not sure what the diff. was
Old Aug 14, 2006 | 08:03 PM
Kevlo911's Avatar
Kevlo for President
5th gen ones are thicker IIRC...
Old Aug 15, 2006 | 07:12 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Kevlo911
5th gen rotors are thicker IIRC...
A33B rotors are a tad bit larger in dia (11.6" IIRC vs 10.9" for A32) ...
Old Aug 15, 2006 | 07:17 AM
Kevlo911's Avatar
Kevlo for President
No, both at 280mm
22mm vs. 26mm for thickness.
http://www.brembo.com/CatalogoBrembo...=NoModifyGuest
Old Aug 16, 2006 | 07:07 AM
hmm so then they would fit....
well after thinking about that some more, would braking be noticably decreased? 4 mm thinner rotors cant really be the best thing can it?
Old Aug 16, 2006 | 07:23 AM
MacGarnicle's Avatar
What kind of driver are you? Will you be needing to make a lot of hard stops because you are a bit of a speed-demon?
Aside from that, the smaller rotors might compromise your ability to stop in an emergency situation, due to the car's extra weight, etc. Not sure how big of a difference a few mm will make?
Old Aug 16, 2006 | 08:11 AM
Kevlo911's Avatar
Kevlo for President
You will warp the 4th gen rotors very fast.
Old Aug 16, 2006 | 08:41 AM
LA02MAX's Avatar
he was talking about the difference between the 4th gen and the 5th gen (A33 00-01) front brakes..The A33B brakes are larger in diameter than the previous years, and they're 11.68"
Old Aug 16, 2006 | 11:35 AM
NmexMAX's Avatar
dot dot dot ...
That's why I typed A33B
Old Aug 16, 2006 | 11:41 AM
LA02MAX's Avatar
But that wasn't relevant to the topic, as he was talking about swapping the A32 rotors onto his A33....not A33B. I was just making it clear to the other people that A33B brakes are different than A32 brakes, but the A33 brakes are the same in diameter, which is what the original poster was asking.
Old Aug 17, 2006 | 07:13 AM
sdoow's Avatar
FRONT:
89-99 = 280x22mm
00-01 = 280x26mm
02-03 = 296x24mm
Old Aug 17, 2006 | 08:09 AM
basically the extra 4 mm is to make room for vents right, the 4th gen arent vented rotors? meaning the slots in the middle? so they wouldnt cool down as fast, therefore causing early warping probly. ****.
Old Aug 17, 2006 | 08:27 AM
Stardust's Avatar
F---ing Kangaroos
All front rotors are vented
Old Aug 17, 2006 | 12:30 PM
NmexMAX's Avatar
dot dot dot ...
Moral of thread... 4mm of width is the difference.
Old Aug 17, 2006 | 03:57 PM
Yeah, basically. Well i'm not sure what to do yet, i'll let you guys know how different it is if i use the 4th gens. Probly not though since theres heat-scoring on one of my rotors as it is.
Old Aug 20, 2006 | 04:57 AM
Alright, i went with the 01's instead of 4th gen since i got a wicked deal through work, they gave me the 72.99 ones for 35 a piece through the commercial department on the stores account so 75 bucks out the door for both. Put them on the other day, much smoother braking now, thanks for the help guys
MAXSE5SPD
Sep 17, 2022 04:00 AM
stevesmax
Dec 17, 2020 11:57 AM
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
