When Replacing Your Calipers, Rotors..............
Old Aug 16, 2006 | 04:14 AM
NeverBepeace's Avatar
And brake pads, do I need to replace the breaking hose? And braking fluid? I took off everything. Just need to get some good rotors, brake pads (hawks I know) and a caliper. Do I need a new braking hose and fluid?
Old Aug 16, 2006 | 04:18 AM
SEmy2K2go's Avatar
Go BUCKS!!!
If your existing lines are in good shape you will not need to replace those. In regards to brake fluid. There are increments at which you should replace the fluid. It is not needed each time you replace brake components.
Old Aug 16, 2006 | 04:51 AM
How would you know your hose need replacing?
Old Aug 16, 2006 | 04:59 AM
NisMoN00B's Avatar
+Cru OG
Replace your brake hoses if they are cracked/leaking. Each time you rotate your tires, they should be checked for breakage.
Old Aug 16, 2006 | 07:38 AM
MacGarnicle's Avatar
switch up the hose with some steel ones - should get you better braking.
Old Aug 16, 2006 | 12:02 PM
How can you tell that you need new brake hoses? I'm not going to spend extra $ when I don't have to.
Old Aug 16, 2006 | 12:10 PM
LA02MAX's Avatar
just check for cracking in the lines....
as for changing the fluid...if you're changing your calipers you have to bleed the brakes, because you need to get fluid into the caliper...
Old Aug 16, 2006 | 12:25 PM
^Thanks.....going to check my hoses some time this week. Is there any type of fluid reccomended?
Old Aug 16, 2006 | 12:32 PM
LA02MAX's Avatar
just get a regular DOT 3 fluid...You can also go DOT 4, but that's mainly for performance reasons, because it has a higher boiling point....just go to an autoparts store and pick one out.
Old Aug 16, 2006 | 06:37 PM
DJ2Max's Avatar
No real benefits for day to day driving, although they would take away one more thing to worry about.
Old Aug 16, 2006 | 09:28 PM
zero2sixtyZ's Avatar
You embarrass me.
Is there a how-to besides the changing rotors/pads threads on how to bleed your brakes? I already searched and checked the FAQs. Thanks.
Old Aug 16, 2006 | 10:43 PM
d3van's Avatar
I'd like to see a how-to on how to properly flush the entire system and replace, then bleed.
Old Aug 17, 2006 | 02:13 AM
westler92
Yeah steel braided hose would be optimal........but not necessary!
Old Aug 17, 2006 | 03:41 AM
raidwolf's Avatar
i've bled brakes b4. can't really do a whole write-up, but one thing, get a friend to help you out. one of you will pump the brake pedal while the other will open/close the bleed screw.
Old Aug 17, 2006 | 04:08 AM
NisMoN00B's Avatar
+Cru OG
You can do the two-man method of bleeding brakes or you can also buy one of those pressure bleeders, albeit it needs some expertise to use.
As with SS braided lines, it's not something you don't have to worry about. The teflon inside could still break and although it seems like a good idea not to worry because it's SS, the danger is still there.
Altogether, brake lines and all components related should be checked every pad/rotor change and tire rotation.
Old Aug 17, 2006 | 06:14 AM
sdoow's Avatar
I recommend going with Goodridge stainless steel brake lines. The quality of their lines is really nice. The only problem is finding a good lead-time on them...
Old Aug 17, 2006 | 11:36 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Guys there are a ton of threads on bleeding brakes and if you are unable to find a useful one on the .Org...here you go (which took 2 seconds to find on the web).
http://www.drivewerks.com/tech/mult_bleed_brakes2.htm
http://www.stoptech.com/tech_info/wp...edbrakes.shtml
Old Aug 17, 2006 | 08:44 PM
You embarrass me.
Thanks SEmy2k2go, I just ordered the whole setup (rotors, pads, ss lines, super blue fluid), just gotta install it all. Thanks again for the links.
Old Aug 18, 2006 | 01:48 PM
SEmy2K2go's Avatar
Go BUCKS!!!
No sweat. Those are two pretty descriptive ones, so you should be fine going off either.
lowpost99
Oct 26, 2025 06:53 PM
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
TheMafia
Sep 4, 2015 08:26 AM
