Need a How-To on LED Mirror Shell Install
Old Aug 16, 2006 | 10:10 AM
2kayznmaxima's Avatar
Hey,
I don't know what i'm doing wrong, but i can't seem to wire up my LED mirror shell lights. I have it connected and it works, but my fuses keep on blowing. Let me know how you installed it and any pics if possible. Thank you all in advance for any help in the matter.
-Tai
Old Aug 16, 2006 | 10:47 AM
PAREDLINE's Avatar
Did you use a relay?
Old Aug 16, 2006 | 11:56 AM
no i didn't
Old Aug 16, 2006 | 01:15 PM
PAREDLINE's Avatar
Thats why the fuse keeps blowing my friend.
You should double check your wiring and use a relay on each side. You can use a wire from the side marker signal lamp on each side to activate the relay. You probably already have 95% of the wiring done to accomplish this.
Good luck
Old Aug 16, 2006 | 02:21 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You do not need a relay...sounds as though you simply have an exposed lead, Tai. I would throw a higher rated fuse (i.e. +5Amps) and see what happens.
Old Aug 17, 2006 | 01:02 PM
i tried a higher rated fuse and that didn't work either...
MaxLife17
Jun 27, 2019 01:37 PM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
flu2000
Sep 8, 2015 02:23 PM
jds22
Sep 4, 2015 01:52 PM
