00' engine misfire
Are all of the coils snapped down all the way?
I had one loose one and it was causing a misfire. pushed it down really hard so it finally snapped down... No problem since.
i have 2000 max se 5 spd. same problems as you guys. my engine was misfire a lot in the beginning when i bought half year ago. i changed the spark plug, MAF, misfiring toned a lot. but there is still a little left. somebody suggests i should changes my coils too. is that way to go for me? thank for any suggestion.
I also have a 5 spd. '02 and I acutally I had to change my coils because of multi-misfire... I could only order 2 (1 front and 1 rear) since it is still kinda new... but by looking at which spark plugs were rounded (there were three) I kinda guessed which coils were bad... but WARNING buying coils are rather pricey I spent close to $200 for a front and rear one... if you're having misfires though 9 times out of 10 the coil and sensor are bad and replacing them is the only way to go.
yeah you'll have to replace the whole set ignition coils/sensors (a rather pricey move) best way to find out which ones are bad is by looking at your spark plugs (if you haven't already changed them)... if they are rounded and the others are sharp tipped (at least mine were) the rounded ones were the misfires... i used to have the this problem and I could only order two coil sets (1 front. 1 rear) for my 2k SE and it ran me $200 but the problem was solved...
shilov
Feb 19, 2024 09:40 PM
ballerchris510
Sep 11, 2015 05:29 PM
