Jacking point
Old Aug 25, 2006 | 08:24 PM
fornimage's Avatar
Jacking point
Does anyone know if there is a common jacking point from the front of the car for a 2002? I did a search and checked the manual and there doesn't seem to be a definite answer to this question. On the front end of the car, there's a cross member that looks like there is a spot for a jack but not too sure about it. Anyone know??? Thanks in advance!
JF
Old Aug 25, 2006 | 08:29 PM
irish44j's Avatar
retired moderator
it's centerline behind the front bumper and splash guards. It looks like a little "mound" or mountain upside-down.
This pic should give you an idea of where it is:
Old Aug 25, 2006 | 10:03 PM
The Law's Avatar
I R The Law
irish couldnt have described it any better
Old Aug 26, 2006 | 12:15 PM
Puppetmaster's Avatar
[/img]
Or you can just jack it up from any point on the crossmember itself. Just make sure the jack is placed well enough on the cross member that it doesn't slip.
Old Aug 26, 2006 | 02:53 PM
Maxfli's Avatar
Rear jacking point?
Thanks irish44j (very nice ride btw)...found the "little mountain" for the front...now how about a center jack point for the back? Or are we relegated to jacking up one side at a time in the back?
Thanks in advance!
Pete
Old Aug 26, 2006 | 03:01 PM
Thanks in advance!
Pete
The center of the rear beam is what the FSM states as the jack point for the rear.
Old Aug 26, 2006 | 04:59 PM
misiek's Avatar
Thanks in advance!
Pete
for the back its safe to just raise by the axle
great pic puppetmaster def printed that one out
Old Aug 26, 2006 | 06:36 PM
00MaxSE's Avatar
Pointy Elbows
The thing is, it gets a little tight if you have a RSB.
Old Aug 26, 2006 | 06:53 PM
LA02MAX's Avatar
any time i jack the rear of my car up i have to remove it...that's probably why i rarely do it
Old Aug 26, 2006 | 07:10 PM
I have a RSB and this is the point I use on each side:
Old Aug 26, 2006 | 08:58 PM
00MaxSE's Avatar
Pointy Elbows
Nice, hey how do you like that jack? I was thinking about getting one. The all aluminum one that is.
Old Aug 27, 2006 | 06:04 AM
Maxfli's Avatar
Thanks for pointing out the jacking points.
Puppetmaster - thanks for the diagram and the pic. Here's a tip back at you that may be helpful to others as well. To keep the car from slipping/moving while on the jack, I put a hockey puck in the cradle of the jack. The rubber puck is hard enough that it won't get torn up and has just enough "give" to "grip" the car, avoiding the potential for slippage with metal contacting metal.
Old Aug 27, 2006 | 08:32 AM
I love it. Its much bigger but its great compared to my little old 2 1/4 ton jack where I had to pump it 20x just to get cradle high enough to make contact with the car; with the race jack you pump it not even once and its already on the car. Plus this jack is low profile so I can get it further down the cross member than with my old jack, which would barely get under the front factory jack point.
Old Aug 27, 2006 | 08:36 AM
You're welcome. Thanks for the tip. My jack actually has a rubber "seat" on it that does just that, but I posted that for the benefit of others who may be using jacks w/o that. That being said, as long as the jack is centered on the cross member, and with all the weight the car is putting down on it, its actually pretty hard for it to slip really. Just better being safe than sorry. Obviously, people should just use the cross member to get the car up and then throw some jack stands under and not leave the jack there as the sole support for the car.
Old Aug 27, 2006 | 08:37 AM
LA02MAX's Avatar
damn, I should have gotten that one. The one I got is like 110 lbs. and it doesn't fit under my car at all I have to use the factory jack to jack up a corner a bit in order for my floor jack to fit underneath the car...but I got it for a good price, so I'm pretty satisfied
Old Aug 27, 2006 | 08:55 AM
fornimage's Avatar
Thanks to all for thier inputs! THat's why I love this forum!
Old Sep 29, 2006 | 11:46 AM
Succinct's Avatar
I devised a way around that problem when I had my BMW 540 and wanted to jack it up by the engine subframe, but it was too low for my floor jack to get under there. I constructed two small-ish wooden ramps out of an 8' x 5/4 piece of pressure-treated deck plank. Three pieces per ramp, each one shorter than the rest, all screwed together. Simple, Fred-Flintstonian stuff.
You then position the ramps in front of your tires, pull the car up onto the ramps, and voila - you can now fit your floor jack underneath the car to your desired jacking point! This was particularly useful after I'd installed H&R's. :-)
Old Sep 29, 2006 | 01:37 PM
LA02MAX's Avatar
great idea! I actually used a couple pieces of wood (although i didn't go so far as to make a ramp with them) under my tires this last time i jacked my car up, and that gave me enough clearance to fit my huge jack under there.
OT: Glacier Pearl 5.5 gen 6-speeds rule!!
Old Apr 26, 2007 | 12:19 AM
hamimp's Avatar
Since I never lifted my car up, I dont know exactly where the Garage Jack Points (in the diagram above).
So, can I use my floor jack at one of the "safety stand points" just to lift the car and then use jack stands to have the car stay lifted. I mean is it safe for the car to lift one side (or tilt the car) first and the lift the other side.
Also, what is RSB?
Thanks.
Old Apr 26, 2007 | 01:20 AM
huffdaddy2008's Avatar
Also, what is RSB?
Thanks.
Ya its safe to lift it from one side. You wont hurt anything as long as your lifting a proper safety point. Your owners manual gives a lil bit better picture of those safety stand points. RSB = rear sway bar.
Old Apr 27, 2007 | 06:29 AM
Get on the ground and look under it. You'll see em. Irish44J's pic up above also has the approximate location of the front point.
Yes, it is safe, but you may risk tearing up the safety jack points depending on if your garage jack has an adaptor or not. Not sure if you care about that. Some people have also had success using a hockey puck or piece of wood.
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
magiconthetire
Oct 26, 2015 09:03 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
homewrecker
Sep 23, 2015 03:41 AM
