ES Bushings, Whats the effect?
Right now I'm on OEM Bushings all around. I want the car to be a little smoother and get a better handling when on the streets. Im on my way to do a make over with my suspension. What effect will i get if i change my bushing from OEM to ES Bushings.
I want to change .
Front sway bar Bushings
Motor Mounts Bushings
And what about the control arm bushings/ what effect will i get if change to ES bushings.
Last Questions
What other bushings can i change that have a big impact on the car.
I want to change .
Last Questions
There's also rear trailing arm and subframe connector bushings.
I feel that when putting in poly bushings, the ride is more precise, not as sloppy. It adds some control and a more solid feel.
With the stiffer motor mount inserts, you may experience more vibration in the cabin at idle, although people have varying opinions of this. Despite that, I think the slight increase in throttle response makes it worth it.
knight_yyz
Nov 1, 2015 01:34 PM
