Emergency brake light always on, where is the switch?
Old Sep 4, 2006 | 10:39 AM
raynist's Avatar
This started happening a few weeks ago. Now that it is cooler, it is always on. Used to just be for the first half hour in the AM. Where is this switch located and how do I get to it?
Ray Nist
Old Sep 4, 2006 | 11:08 AM
A33 VQ30DEK's Avatar
you need to add some brake fluid.
Old Sep 4, 2006 | 11:13 AM
raynist's Avatar
Cool, I will try this.
--Ray
Old Sep 4, 2006 | 11:17 AM
raynist's Avatar
That was it.
Thanks for your help.
I never would have thought to check that.
--Ray
Old Sep 4, 2006 | 11:24 AM
P. Samson's Avatar
If the light is on due to low fluid level it is essential that you check for leaks as well. Check around all four calipers and hoses for obvious leaks. If the system is "tight" the light should not come on due to the normal drop in level due to pad wear if the system has been maintained correctly.
Old Sep 4, 2006 | 11:42 AM
Metal Maxima's Avatar
SHIFT_om nom nom nom
IF it's not the fluid...
Switch is located beneath the middle console. Remove that, and you will see the contact switch that completes the circut for the e-brake. There are two metal points that come into contact when the brake is engaged.
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
Nismo_Guy89
Aug 24, 2015 09:49 PM
Samedi
Aug 13, 2015 04:05 PM
