Brakes squeak while reversing. Why?
Why do my brakes make this deathly annoying/girl like screeching noise when I'm in reverse and applying the brakes? My pads are brand new, and my rotors are new OEM installed about 6 months ago.
i remember two of my friend's car, had squeaky brakes everytime they went into reverse and applied brakes...it turns out it was their rear brakes...all they did was buy new pads and rotors...and problem solved...
i'm not sure if this will apply in your case, however...
Originally Posted by xnyc
make sure the shims and backing plates on the pads are lubed. get some brake cleaner and spray between the pad and rotor contact surface.
Squeaky Brakes
mine does the same thing, I was told it was because the pads are worn in one direction (forward) that sometimes when applying them in reverse direction they will squeal. My pads and discs are new also. Hope this helps, Steve
Mine used to do that... I did a brake job all around about a month ago, and the rears were compl. worn. As a matter of fact, one of my rear tires locked up in reverse cuz i procrastinated so long, almost ruined one of my rims. Word of advice, dont wait, check them now just in case even tho they are brand new. BTW, both my rear calipers were frozen, maybe you have the same prob?
Originally Posted by NYPD-Arnold
All pads are BRAND new and were installed at the same time.
Who installed them? Methinks they need to be looked over again...
We could hypothesize as to what is wrong with them, but you really won't be able to see if anything is maligned or rubbing unless you get them apart.
![slant](https://maxima.org/forums/images/smilies/slant.gif)
04-16-2020 05:15 AM
06-06-2017 02:01 PM
HerpDerp1919
09-29-2015 02:02 PM
