Transmission fluid change ... part #'s correct???
For a 2000 SE, are these the correct part #'s
tranny pan gasket 31397-80X01
19mm tranny drain plug 31377-31X06
tranny screen 31728-80X04
Are there any other parts I need to change while I'm changing the fluid?
Besides the gasket, are the drain plug and screen necessary to change?
Thanks much!
Thanks much!
Thanks much!
Thanks much!
Originally Posted by VaporHead
You don't need to do any of that to change your fluid. There's a write up in the Stickies on how to change it just through the in/out lines going to your radiator. I believe you can't get all the fluid out by just dropping the trans pan. Only like 4 qtrs I believe is in the trans pan, leaving 4-6 more quarts elsewhere. Good luck m8.
Thanks much!
Thanks much!
MAXSE5SPD
08-23-2015 12:06 PM
