squeaky rear springs, stock setup
i notice recently i've been getting a squeaky noise from the rear suspension...i further diagnosed it by pushing down on my trunk...and its definitely coming from the rear suspension...its a squeaky noise...same thing when you open a REALLY OLD door...
i coulda sworn there was a thread about this issue...and someone used some kind of spray to cure this...does anybody know what kind of spray it is? i have both wd-40 and silicon dry lubricant...
this happened to me when i switched my maxspeeds on. pull your carpet up in the trunk and make sure all 6 of those nuts are tightened down fully. that was my problem. if that doesnt solve it then i dont know.
anybody else have information about this?
how many miles does your car have? Cuz high mileage probably indicate the struts are worned out. Ironically my stock SE shocks are getting too harsh and stiffer when I drive over a very rough pavement. Causing the car to shake. I don't remember when I got it brand new being this stiff. SInce my car has 48k on the clock. i wonder if the struts gone bad or something.
Originally Posted by bsetiawan
Make sure your spring isolator/insulator is in good shape and that the springs are not in contact with the spring seats.
hehe, i hope its not a bad strut...i doubt it either...only becuz i have 28k on the suspension....and when i jump on the rear door sills to rock the car, it rebounds very smoothly
is there somekind of spray i can use?
bump..
i tried to tighen the bolts and they were all in factory specs...i also sprayed the springs with silicon spray....it helped for a little bit...but now the noise is back!!
i could have sworn theres a magically spray to help cure squeaky springs and what not....whats it called you guys? i cant find the thread
Just wondering, did you use the red spacer between the strut mount and the chassis ?
what else do ya suggest?
Originally Posted by steven88
yeah i did...its so flimsy, that i doubt this will even make a difference...
It does make a difference if you take corners like you stole the car. That flimsy thing prevents metal to metal contact. Since our chassis is like TOFU compared to german cars, I think the chassis will flex with respect to the strut mount.
Originally Posted by TopSpeedNY
I had the same thing in the back and used some spray and it work a week allready no noise so far let me know i can try to get the name allright bro.
Mike
Mike
BUMP.
Sorry to bring back an old thread, I've been searching and searching as I am having the same problem (and I don't want to get bashed on for making another thread). I already sprayed and nothing. The noise does not seem to be coming from the springs. What could it be? I live in an area that has a lot of speed bumps and this noise is driving me INSANE(I am new to this and know 0% about suspension). Everything on the car is stock, and the shocks don't seem to be blown out but who knows, you guys are the experts. Here's two videos of the annoying sound. Any help will be greatly appreciated.
http://s293.photobucket.com/albums/m...t=DSCN5884.mp4
http://s293.photobucket.com/albums/m...t=DSCN5883.mp4
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
