Automatic Transmission Flush
Old Sep 15, 2006 | 08:42 PM
colinchan167's Avatar
When do you suppose to do the transmission flush? My 01 maxima has 47k miles, should I do the flush now or wait until I hit 50k miles.
Old Sep 15, 2006 | 09:50 PM
PAREDLINE's Avatar
3000 miles will pose no difference. Thats like wondering if you should take a shower now, or after scooby doo is over.
Old Sep 15, 2006 | 09:58 PM
beancooker's Avatar
^ +1..........
Old Oct 14, 2006 | 01:45 PM
q45Owner's Avatar
Agree - you 60K is not a magic number
Old Oct 14, 2006 | 03:26 PM
q45Owner's Avatar
I recommend 30K or 2 years whichever comes first.
Old Oct 14, 2006 | 09:40 PM
JiggaD369's Avatar
I just bought a 02 SE back in May. I don't know if the previous owner got it done or not. It had 68K on it and now it has 73K. Should I replace it or is it too late?
Old Oct 14, 2006 | 09:43 PM
wanaMax's Avatar
changing the AT fluid is no big deal, its not like you are going to gain anything. I changed mine at 110,000 and it looked fine, and Im sure it hadnt been changed in a long time. but anytime is good I guess. its nothing like your oil.
Old Oct 15, 2006 | 04:41 AM
PAREDLINE's Avatar
you must work for jiffy lube. 30K? this fluid is designed to last the life of the transmission. Provided you use Nissan-matic.
60k change if you're really ****. I'd say at least 100k for most drivers.
Being that a new transmission can cost up to $2500 i'd use nissan matic fluid only. What's that gonna cost you? $30 more?
Old Oct 15, 2006 | 06:47 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
follow my sig.........
Old Oct 15, 2006 | 07:30 AM
Derek626k
The owners manual recommends flushing the fluid every 30 k miles. I guess Nissan doesnt think the fluid lasts the life of the transmission. I flushed mine with mobil 1 synthetic atf at 36k miles when I bought the car. I worked at Speedee Oil Change and Tune Up and just used our machine with 14 quarts cost me like 80 dollars.
Old Oct 15, 2006 | 07:40 AM
PAREDLINE's Avatar
That's a great write up. My only question is... you refilled the transmission just to drain it again? Can you drain the fluid in the torque converter without adding new fluid? So drain it all off... then put in new fluid.
Old Oct 15, 2006 | 08:11 AM
Lontar1's Avatar
the oil in the converter will be pushed out before the new one. I added 4.5 Q in the same +- anmount that I took out when you remove the plug. You need to keep oil inside the tranny at all times while you run the engine and go by all the gears. If I were you I wouldn't do it but it is up to you. The oil will change colors and then you know that all your old oil is out. Good luck
user 11122324
42
Jul 18, 2022 03:35 PM
ef9
Oct 4, 2015 08:43 AM
Pied
Sep 26, 2015 03:29 PM
