cross drilled+slotted Rotors
Old Sep 25, 2006 | 05:31 PM
maxs4life's Avatar
I was going to put some crossed drilled and slotted rotors, but many people are telling me that there not worth it. Why Not?
What the best rotor out there.
I wanted to put them with Hawks hp pads.
Old Sep 25, 2006 | 05:40 PM
illlojik's Avatar
I C U
reason being....
1-cheese grater effect on bake pads
2-x/d rotors tend to form cracks around the holes which leads to.......
The vets around here will tell you the same, to search, and to just stick with Brembo Blanks. You won't regret it
Old Sep 25, 2006 | 06:15 PM
maxs4life's Avatar
Originally Posted by illlojik
reason being....
Brembo blanks vs OEM Rotors
Old Sep 25, 2006 | 06:16 PM
Mints33's Avatar
I had crossdrilled rotors on my last car, and they started to crack around the holes in less than a year. So, blanks has my vote!
Old Sep 25, 2006 | 06:24 PM
illlojik's Avatar
I C U
OEM has a habit of warping prematurely. Brembos would be your best bet. Irish44j who is an autocross maniac uses/used those for a while with no probs.
Old Sep 25, 2006 | 06:49 PM
irish44j's Avatar
retired moderator
good Lord....do we REALLY have to have this exact same thread every freakin' other day?
Holdup....didn't you post basically this same thread about 4 days ago????
http://forums.maxima.org/showthread....hlight=drilled
seriously. Delete this crap and just bump up your previous thread. The amount of drilled/slotted rotors threads around here is getting WAAAAY out of control. seriously.
I have not used brembos on the maxima, that I can recall though maybe I'm forgetting...... I'm currently running Kiriu 6th gen rotors (kiriu makes the OEM 6th gen rotors, and they're basically identical). Before that, another set of OEM 6th gen rotors (sold with previous BBK). Before that, OEM 5th gen rotors.
Brembos are good, but I don't feel they're any better than OEM. Also I thought I had explained to you that 90% of people who think they've "warped" their OEM rotors have NOT warped them. They just have uneven pad material buildup due to garbage OEM pads...which will happen on ANY rotor if you use OEM pads.......
Old Sep 25, 2006 | 06:51 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Enough with the duplicate threads already.
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
rnb754
Sep 14, 2015 11:39 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
