Gear Shift Question
Old Sep 27, 2006 | 11:26 AM
Brianne82's Avatar
Gear Shift Question
Ok mom just got a 2002 Maxima SLE And I noticed when the key is not in the car you are able to take the care out of park without pressing the brake. I have a 95 Maxima & you can not do this with mine. Is her car suppose to do this or is something wrong with it???? Any feedback will be greatly appreciated...
Old Sep 27, 2006 | 12:13 PM
BLUEMAX01SE's Avatar
Check the shift lock ????????????
Old Sep 27, 2006 | 01:06 PM
misiek's Avatar
did u mean all the way like in reverse or just a but to the side cuz its normal for it to go to the side just not and lower then that
or like blue said check the shift lock
unless its a new option on the "SLE" lol jk
Old Sep 27, 2006 | 01:45 PM
Brianne82's Avatar
if the car is turned completely off i can put the shifter all the way from park into first gear.... How do I check the shift lock?
Old Sep 27, 2006 | 04:42 PM
NmexMAX's Avatar
dot dot dot ...
Do you have an owners manual?
Old Sep 27, 2006 | 05:24 PM
Brianne82's Avatar
yes i do
all it said was something about not being able to get it out of park if the battery was low or dead to push a button or something...
Old Sep 27, 2006 | 05:34 PM
NmexMAX's Avatar
dot dot dot ...
Seems as if your car is in that mode and needs to get out of that mode.
Old Sep 27, 2006 | 05:37 PM
Brianne82's Avatar
OK I'll try pushing that button.
Old Sep 27, 2006 | 05:58 PM
NmexMAX's Avatar
dot dot dot ...
Try reading the next page of the manual if you still have problems.
Old Sep 27, 2006 | 06:24 PM
I'm not sure where you're shift lock is located on the 02 5.5gen, I know mine is right on the shifter plate just above the "P", if it is up, you can just push it down into place. May want to check with a 5.5 genner. Good luck Brianne, but the shifter should not be able to shift gears without the key in the ignition and turned to the acc position I believe.
Old Sep 27, 2006 | 06:42 PM
Brianne82's Avatar
OK I tried reseting the shift lock by pressing the button & nothing happen. I've read the whole owners manual and it says nothing about it except that it's not suppose to do it. So does anyone else have an idea??????? Or does anyone else's do this?
Old Sep 27, 2006 | 06:54 PM
NmexMAX's Avatar
dot dot dot ...
Does this look familiar
"If the vehicle is driven under extreme conditions such as excessive wheel spinning, subsequent hard braking, the fail safe system may be activated. This will occur even if all electrical circuits are functioning properly. In this case, turn the ignition key OFF and wait 3 seconds. Then turn the key back to the ON position. The vehicle should return to its normal operating condition. If it does not return to its normal operating condition, have your NISSAN dealer check the transmission and repair it if necessary"
Have you tried this?
Old Sep 27, 2006 | 07:59 PM
Brianne82's Avatar
Tried that also everything on the car works fine. There is only 30,000 miles on it. Suppose she'll have to take it to a Nissian dealership which she really don't won't to do. Thought I'd check here first for her. Thanks for all ya'lls help if ya'll have any other suggestions let me know.
Old Sep 27, 2006 | 08:17 PM
Maxim(a)SerjVQ's Avatar
Nightmare = Reality
there's a screw under a small covering on the shifter plate labeled "shift Lock" for the A/T maxima 02-03. You should be able to put a small screwdriver into the gap and pull the cover off that screw hole. I THINK it needs to be rotated a half-turn and you should regain the shift lock. It's typically disengaged for towing purposes. Let me know if this helps.
Old Sep 27, 2006 | 08:39 PM
Brianne82's Avatar
on mom's shifter plate she has the small covering which pops out but under that there is no screw it is like a button which can be pressed down. I've tried with the car on, off, with the brake pedal pressed, with it not pressed, with the car in ACC postion& so on by chance would that button happen to rotate?
Old Sep 28, 2006 | 06:53 AM
9DTALON's Avatar
No it won't rotate. It is likely that your shift lock solenoid is dead/ stuck. Part number is 34970-5Y710 list is 60.25. To check it, remove the cover plate around the shifter so you can see the solenoid and to gain access. Withe the ignition turned to on tap down the brake pedal while feeling/ listening to the solenoid. It should click every time you tap the pedal. Normally you can hear or feel the solenoid without removing the plate, but just to be sure i'd remove it. Good luck.
Old Sep 28, 2006 | 08:22 AM
Good deal Talon, I was going to mention the same thing to Brianne! Good luck!
Old Oct 8, 2006 | 12:43 PM
regent1's Avatar
Gear Shift difficult to get out of park
Have a 02 Maxima SE, automatic, the shifter at times is difficult to get out of park. Has anyone had that problem? Could the lock solenoid be the problem?
Old Oct 8, 2006 | 02:16 PM
VaporHead
Do a tranny flus and use your parking brake. Do you park on a incline? If you do, and you dont use your e-brake, there is alot of pressure on that tranny shifter. Always use your e-brake when in Park and BEFORE you release your brake pedal.
Old Oct 9, 2006 | 03:29 PM
Matt_01SE_20th's Avatar
if she just got it the dealer shoudl cover it even if it is out of warranty. its called good faith.
Also, Vaporhead, there is no pressure on the shifter itself. its in the tranny and if it fails the car will roll, not shift out improperly. two different situations.
Old Oct 9, 2006 | 05:22 PM
A little off topic but hey what's up Matt01SE20th. Another AE 20th not to far from ya! I'm in Lockport. I have a cousin who lives in Chicago/Midway area with a 5 spd AE. We should do a 20th AE meet!
Old Oct 10, 2006 | 03:43 PM
regent1's Avatar
I always use my parking brake and it makes no difference on an incline or level. The shifter sometimes is difficult to get out of park. I purchased the car used, it was a program car. I am sure they didn’t use the parking brake. Wonder if the shift lock solenoid sticks? Can you tell by removing the gray cover plate?
Old Oct 10, 2006 | 05:41 PM
BLUEMAX: good to see some more in the area, i dont know about a AE meet, might be fun, but definately hit up the meets we have in the area, normally up near schaumburg.
regent: the shift lock solenoid is an electro-mechanical part. When it switches you can hear it, not loudly though. THe best way to test is to step on the brake lightly and find the point at which it engages and learn the noise. after that move the brake pedal quickly, it should engage at the same point. its hard to explain in words, try it out and you will most likely know what i am talking about pretty quick. it is not a common part to fail, no moreso than any relay on the car.
Old Dec 8, 2008 | 06:42 PM
colo's Avatar
How do you remove the Shifter cover plate in a 2000 maxima se? Thanks
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
