Intake problem?
Old Oct 5, 2006 | 10:27 PM
machinehead131's Avatar
Intake problem?
Hey guys i just installed my berk intake with the apexi filter on my 03 maxima..After installation i took it out for a test spin, awsome! I have a concern after that when my engine was warm, say i parked my car and filled up, turned off the motor. When i started it back up it would just die on me...i would have to mess with the throttle a little bit and then it would idle normally again, is this the ECU trying to learn again because i did unplug my batt for 24 hours if that helps, it hasn't stalled recently and has been pretty good i just want to make sure everything is ok!
Old Oct 5, 2006 | 10:37 PM
OutMaxxed's Avatar
u might have messed up your MAF sensor if it just "died". Did u drop the sensor or could have possibly damaged it? Any Check engine lights?
Old Oct 5, 2006 | 10:57 PM
vq356sp's Avatar
El Mas Noob Del Org.
On our 5.5 gens we have no reason to unplug the battery, try to reset the ecu here is a link to instructions on how to
http://www.technosquareinc.com/350reset.htm
Did you get a cel light? Hope the reset helps but it definately sounds like a maf problem
Old Oct 6, 2006 | 05:02 AM
No CEL or anything car runs fine now i have no idea why it did it. Ill try reseting if i encounter any problems i guess.
Old Oct 7, 2006 | 01:51 PM
super6's Avatar
if it runs fine i guess ur good. just check the vacume hoses, could be a maf but unless u droped it while changing its unlikely.
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
