FOG light replacement HOW TO?
Old Oct 9, 2006 | 12:22 PM
rmd0311's Avatar
Alright this might be way to simple... Just having a hard time::: Trying to follow:
http://www.innerbean.com/housecor/piaa_fogs.html
Is this the same for the 5th Gen??? Or is it different?
Old Oct 9, 2006 | 12:24 PM
nadeemp8's Avatar
Only difference for 5th gens is when you get to the housing there is only one screw you have to unscrew on the bottom of the foglight before pushing on the back of it to pop it out.
Old Oct 9, 2006 | 12:32 PM
rmd0311's Avatar
OK., Now to disconnect the Fog before unscrewing... The housecor site says push a tab to pull out the harness... Which tab is this? This is what I see....
Old Oct 9, 2006 | 12:42 PM
SoonerFan's Avatar
Cletus
to disconnect the harness - push in that tab with the lines across it
to remove the entire harness - its underneath the harness...where it connects to that black medal bracket. it will pull away from the fog light housing
Old Oct 9, 2006 | 01:15 PM
rmd0311's Avatar
Last question regarding this... Is it a must to lift the car up?
Old Oct 9, 2006 | 01:18 PM
SoonerFan's Avatar
Cletus
no.
its actually easier to remove the headlight and do it from the top
Old Oct 9, 2006 | 01:52 PM
burnurass's Avatar
you can use ramps too if you want.
Old Oct 9, 2006 | 02:06 PM
ColdSHO's Avatar
second doing it from the top. much easier to realign when ur done if needed.
Old Oct 9, 2006 | 07:21 PM
colinchan167's Avatar
Can you aim the fog light?? Thanks
Old Oct 10, 2006 | 07:51 AM
Trurida18's Avatar
no it isnt a MUST...but it for damn sure helps....i did mine without lifting my car or putting it on ramps, and i CAUGHT HELL
Old Oct 10, 2006 | 08:22 AM
rmd0311's Avatar
I tried doing it on Saturday and it was nearly impossible. I wll buy Jack Stands and do it. I needed to buy jack stands anyway. This makes as good excuse as ever.
Old Oct 10, 2006 | 08:27 AM
Trurida18's Avatar
with that being said, i think i need to go buy some as well
Old Oct 10, 2006 | 09:32 AM
SoonerFan's Avatar
Cletus
or...remove the headlight and do it from the top. you are standing up so its so much easier
Old Oct 10, 2006 | 03:03 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
I found it so much easier to do from under the car. on each side there's a 10 mm bolt, a phillips-head screw, and a regular body clip.
remove those and push the plastic covering out of the way.
use a 10 mm ratchet and remove the 2 nuts behind the foglights. unclip the harness and push the foglights out. that's it. i suggest placing a rag or something in front of the fog lights so they don't fall out and crack when you push them out.
Old Oct 11, 2006 | 06:53 PM
nadeemp8's Avatar
Yeah, it took me like 10 min on each side to do it from the bottom, it was pretty easy...as long as you have a jack...
Old Oct 11, 2006 | 07:15 PM
rmd0311's Avatar
I'm sure my problem was the being uncomfortable under an un-raised car. Will definitely buy Jack Stands this weekend and try again.
Old Oct 12, 2006 | 03:25 AM
naxray's Avatar
Here's another write-up for ya:
http://www.moodym.com/maxima/tech/foglight.html
Good luck - I haven't tried it from the top but with ramps it was not hard at all.
Old Oct 12, 2006 | 04:26 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
while replacing mine, i adjusted them a few turns of a 8mm box wrench and found them to work alot better than before. i realize fog lights are to light directly down in front of the car but being low to begin with and the car being lowered, it really help out.
Old Oct 13, 2006 | 05:15 AM
trigger005's Avatar
ur comments dont apply here the 5.5 gen fog light assembly is different from the 5.0 gen
the harness tab was very hard 2 push in and take out
the fog assembly was also very hard to pop out
i would suggest a hammer or rubber mallet
good luck
Old Oct 13, 2006 | 05:34 AM
upstatemax's Avatar
good luck
If it was that hard for you, you have some "special" problems...
If it was done right, it takes less than 3min to get each of them out and it takes little effort.
I personally think taking them out from UNDER The car is much easier. All you have to do is pull back the splash guard and they are right there... Easy access to the 10mm bolt on the bottom, harness, and tab to push out.
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
