ecu
Old Oct 14, 2006 | 10:20 AM
opanick's Avatar
ecu
well i just got a new maf and installed it, now is doing the ecu reset procedure with the gas pedal the same as the dealer reprogramming?
Old Oct 14, 2006 | 11:29 AM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
they are not the same procedure but the only 5th gens that needed the reprogramming via the consult 2 is the 2k/2k1. the reset will only set certain parameters to an unlearned state so the car is forced to see new readings. you really only need to reset the ecu if the cel is on, otherwise the car will pick up everything it needs simply by driving.
Old Oct 14, 2006 | 11:31 AM
opanick's Avatar
so i have an 2002 and i just did the maf replace, so just drive it, do the pedal reset, or consult 2 reset?
Old Oct 14, 2006 | 11:33 AM
sloppymax's Avatar
if the check engine light is on then you can do the reset to get it to go away. if its not on then put it in, plug it up and drive.
Old Oct 14, 2006 | 12:05 PM
opanick's Avatar
well my cel is on cuz my o2 sensor is bad
Old Oct 14, 2006 | 12:24 PM
Mass_Media's Avatar
Mass_Media™
Get your codes checked see what codes you throw...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
