Going to invest in new spark plugs for an 03. Anything I should consider?
Old Oct 23, 2006 | 01:59 PM
pbn85's Avatar
Gas mileage on my 5.5 gen has gone down. Mileage is 50k and I dont know if the previous owner ever replaced the spark plugs. Im thinking of getting Bosch. What are your thoughts?
Old Oct 23, 2006 | 02:01 PM
Mints33's Avatar
why??
I wouldn't use anything other than NGK!
Old Oct 23, 2006 | 02:10 PM
mist max2000's Avatar
Bosch > FTL
everyone on here will tell you the same thing.. our car doesnt run on bosch..
IMO put the same ones that came out back in NGK double plats
Old Oct 23, 2006 | 02:21 PM
pbn85's Avatar
ohh...I had bosch spark plugs on my 01 Prelude so I assumed it would be great on the Maxima also. Cool I will stick with NGK in that case. Double platinum correct? Do I have to go to the dealer for these or can I buy them elsewhere?
Old Oct 23, 2006 | 02:32 PM
Mints33's Avatar
Advanced auto or O'Reilly will have the best price on the plugs locally, they're still going to run ya about 10 bucks a plug.
Old Oct 23, 2006 | 02:38 PM
MaxBlu5's Avatar
Replaced my spark plugs this past weekend with NGK Iridium IX, so far so good, car idles better, and hesitation in the morning w/ the engine cold is literally gone. Have about 82k miles on my car.
Old Oct 23, 2006 | 02:47 PM
yeah like mints said..advanced and it will be about 60-65 bucks total.. and dont try to get the reg. NGK plats that they have for like 3 bucks, cuz i tried to be cheap and learned my lesson the hard way,. had to pull the crap cheap plugs out and put the double ones back in ... so pay the extra money and do the job once
Old Oct 23, 2006 | 04:05 PM
pbn85's Avatar
thanks dudes
Old Oct 23, 2006 | 07:00 PM
MacGarnicle's Avatar
apparently Maxima's are picky about their plugs. was talking to my guy at the parts department at my dealership and he said every car thats come in that doesn't have the specific NGK plugs in em, runs bad. they're expensive, but its a key part of your engine.. dont mess around.
Old Oct 23, 2006 | 08:00 PM
Snolife's Avatar
What we have here is a failure to communicate
Does anyone know what the exact part number for the NGK or is there one? Thanks.
Old Oct 23, 2006 | 08:05 PM
NmexMAX's Avatar
dot dot dot ...
Try reading the stickys.
Old Oct 23, 2006 | 08:07 PM
BigFly_2K2SE's Avatar
According to midwaypartsteam.com, part number for PLF5RA-11 NGK plat plugs is 22401-5M015.
Old Oct 23, 2006 | 08:09 PM
When I read the stickies I could not find a Nissan part number for our plugs. PLFR5A-11 is listed extensively, but this is an NGK number not a Nissan number.
Old Oct 23, 2006 | 08:42 PM
Orgullo's Avatar
$$ Ballin on a Budget $$
I was just about to start searching for this myself. Good info, by the way is there a specific torque we should use to put them back in?
Old Oct 24, 2006 | 07:13 AM
http://www.ngksparkplugs.com/apps/ca...60000&country=
Specify your car and it'll give you the right part #. Take the part # to the dealer and they'll have them.
Alternatively, if you do not want to pay $17 per plug, go to mynismo.com and get them from there. Half the price my dealer wanted.
Old Oct 24, 2006 | 07:24 AM
Killercam2's Avatar
Thanks for the info... Good thread
Old Oct 24, 2006 | 07:35 AM
pbn85's Avatar
are these the ones I should get?
http://www.mynismo.com/products/?id=4043
B/c I am ready to order them. thanks
Old Oct 24, 2006 | 08:08 AM
pbn85's Avatar
should I go for the iridium or double plats?
Old Oct 24, 2006 | 10:37 AM
i dont remember exactly.. but im pretty sure that this number PLFR5A-11 was the number that is on the actual plug itself...if u go to autozone or whoever you'll be able to find the right one no prob,.. IMO it makes no difference form the dealer or not because all of mine came pregapped and were perfect (i checked)
Old Oct 24, 2006 | 10:38 AM
NmexMAX's Avatar
dot dot dot ...
Cripes my head hurts .....
Old Oct 24, 2006 | 05:06 PM
getbigtony's Avatar
use bosch and you'll probably get misfires later on.. especially the stupid quad tipped ones..
http://www.partsamerica.com/ProductD...pe=960&ptset=A
$6.96 at advanced auto or whatever partsamerica you have around u
strauss? advanced? dont remember wat else
Old Oct 24, 2006 | 05:11 PM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
how often are we suppose to change the plugs?? i forget...
Old Oct 24, 2006 | 06:04 PM
Mints33's Avatar
Manual says every 100K, but personally every 50-60K.
Old Oct 24, 2006 | 06:11 PM
3xSHOloser's Avatar
i'm at 135k on my 02 and have not had any problems....yet maybe i should stop putting it go ahead and get it done. does the intake gasket have to be replace and can it be reused?
Old Oct 24, 2006 | 07:02 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by 3xSHOloser
does the intake gasket have to be replaced or can it be reused?
http://forums.maxima.org/showpost.ph...&postcount=123
Old Oct 24, 2006 | 07:15 PM
overeducated's Avatar
fact.
Factory knows best?
Old Oct 24, 2006 | 07:37 PM
NmexMAX's Avatar
dot dot dot ...
Admins & Moderators know best, and with your useless postings, you will soon know more than you did prior to your hollow posts.
Originally Posted by overeducated
Factory knows best?
Old Oct 25, 2006 | 04:34 AM
MaxBlu5's Avatar
Those are the ones I put in my 5th gen Max, and they are running fine. The car idles smoother and runs pretty well when it's dead cold outside at first engine start up.
Old Oct 25, 2006 | 05:37 AM
NmexMAX's Avatar
dot dot dot ...
VQ35 plugs are longer, so do not use DEK plugs.
Old Oct 25, 2006 | 05:37 PM
madmax20019's Avatar
Yes
do not strip the holes in the block...get a professoinal to help.
Old Oct 25, 2006 | 05:54 PM
NmexMAX's Avatar
dot dot dot ...
... I've done this many times and I am by no means a professional.
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
