nismo fuel pressure reg.
Old Oct 28, 2006 | 10:18 AM
absoundlab
Will a nismo fuel pressure reg do anything on a vq30dek n/a?
Old Oct 28, 2006 | 11:28 AM
SoonerFan's Avatar
Cletus
no.........
Old Oct 28, 2006 | 11:29 AM
NmexMAX's Avatar
dot dot dot ...
Too vague of a question. So you get a semi-vague answer.
If you don't know to do with it, no.
Old Oct 28, 2006 | 04:27 PM
steven88's Avatar
Need A Light?
I think it makes it richer...at least the default setting? I'm not totally sure
Old Oct 28, 2006 | 04:56 PM
absoundlab
If I purchase a nismo fuel pressure reg and install it on my 5th gen maxima
(vq30dek) and I increase fuel pressure will that make a big difference in performance?
Old Oct 28, 2006 | 05:04 PM
SoonerFan's Avatar
Cletus
no..........
still the same answer.
1. if you increase the pressure you have to get larger injectors
2. if you increase fuel, you have to increase air
3. if you increase fuel and air, you have to let the car know (reprogram the fuel/air with the ECU)
Old Oct 28, 2006 | 05:08 PM
NmexMAX's Avatar
dot dot dot ...
No you don't.
Old Oct 28, 2006 | 05:19 PM
absoundlab
ok so is it confirmed that if you add a nismo reg to a n/a 5th gen it will do nothing for the car?
Old Oct 28, 2006 | 06:38 PM
RA030726's Avatar
I'm nutty for Nissans
If you had a bunch of bolts ons, went to the dyno and your a/f is wack then sure it can help. But an AFPR on its own is so crude and pretty much useless unless you were either super rich or super lean.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
05RLS2
Apr 14, 2016 11:49 AM
