VQ35 strikes again...
#41
Hey guys...I did my plugs this weekend and encountered the same problem...the plug chamber in the back closest to driver's side had oil in it....all of the others are fine.
I loose only about a 1/4 quart of oil or less betweeen 3000mi oil changes...How urgent is it that I replace the valve covers...because I was thinking about waiting till spring when it warms and I am really busy with things right now too!!
Thanks in advance
Thanks in advance
#42
Thanks in advance
Thanks in advance
But really and truly, I don't even think that I needed to replace the VC....when I took the VC off I noticed that the seal on cylinder #5 was over the top of the metal spark plug chamber and the other ones weren't. This is what was causing oil to leak into it...If I were to have just adjusted the seal down further, it would have provided an oil tight fit...however, I also noticed that the material the new Valve cover (I bought the 6th gen one) was much more rubbery. The seals on the valve cover on my car almost felt like they were made of plastic, which as you know slides against smooth materials much easier than rubber. I think this is what they improved in the new VC so I think that I have less of a chance of this happening again. Anyways, good luck and I ran into some problems getting the oil out, but eventually I got enough out to where I could just pull the plug and nothing would be affected. I'll be checking it periodically just to make sure it's not like that again.
#43
Originally Posted by LA02MAX
well considering I have no clue how long it's been like this, I can't say how urgent it is. My car was running fine and now that I replaced my rear valve cover, cleaned all the oil out, and installed new plugs, my car isn't running that differently. Unless the oil has water in it, it really can't do too much to the coil permanently, and it wasn't touching the actual spark plug so when I pulled that plug out, the tip was not oil fouled..the oil was sealed on top of the spark plug.
thanks for the info...i will buy the 6th gen cover when i do replace then as well
#44
Originally Posted by MIKE2K2
It comes with a new PCV valve as well.
I changed my rear cover this summer. Make sure you clean off the bolts with a wire brush, and torque them evenly and SLOWLY. 9-26 inch pounds isn't that much, and it is VERY easy to break a bolt.
#46
Originally Posted by Epacy
You stated that 9-26 in/lbs wasn't that much, making it sound like that is all you have to tighten. Yet the diagram says to tighten further to 65-82 in/lbs. Did you do that also?
Originally Posted by nk2k2
is there a way of checking to see if the valve cover is cracked or not w/o pulling the plugs?
#47
That's kind of weird, because I accidentally over-tightened one of my bolts and snapped it. I had my torque wrench set to 20 lbs. but I didn't feel the click and kept tightening a little more (probably not 60 ft-lbs...) and it snapped right off...I tightened all mine to about 25 or 26 and haven't had a problem since. As a matter of fact, I just took off my upper IM today and there are no leaks whatsoever...
#48
So, you didn't tighten as mentioned in the second section of the owner's manual? Just to 9-26 inch/lbs.
#50
Originally Posted by Trurida18
^^wtf........so i guess stating "POST # 21" INCLUDING ANY SPACES!
WAS ALOT MORE TIME CONSUMING THAN JUST TYPING xx,xxxK miles??!
WTF!
WTF!
#52
Originally Posted by pimperz2000
man i'm at 63k i hope when i attempt changing my plugs that i get that surprise.
#53
James92SE
142
01-02-2024 10:23 AM
