LED in Keyring always on?
Old Nov 1, 2006 | 04:32 PM
theMax's Avatar
I put a LED in for the keyring light and it seems like it is always on when the car is off and the key is out, but not as bright. It is not enough to drain the battery. Anyone else notice this??
Old Nov 1, 2006 | 04:44 PM
irish44j's Avatar
retired moderator
yes....since there's a delay on the bulb that usually is hooked up there, the LED (which uses ALOT less power than a bulb) takes about 20 minutes to "burn off" the residual power.
No, it will not drain anything. If you check back to your car after 20 minutes or so, you'll see that it is off...
Old Nov 1, 2006 | 05:47 PM
n3985's Avatar
大陆弟弟
Mine turns off after approx. 15 seconds.
Old Nov 1, 2006 | 06:24 PM
MaxBoost925's Avatar
Drug Money
Same with mine, I'm stock green because I like it turns off really quick when the car is off.
Old Nov 1, 2006 | 06:25 PM
steven88's Avatar
Need A Light?
you don't have to worry...mine is like this as well
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
