removing door panels?
Old Nov 9, 2006 | 02:48 AM
lalaMAX's Avatar
i got a new set of speaker, just wanna know what is the best way to remove the rear door panel...
anyone got a how to or anything like that?
i dun wanna screw anything up sorry, and thanx alot...
Old Nov 9, 2006 | 07:05 AM
GigEmAgs07's Avatar
go to paradox-systems.com and look at the installation how to for the led mirror shells for the 00-01 max. Has pics and shows exactly what to do. it takes a screwdriver and about 2 minutes.
Old Nov 9, 2006 | 07:56 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
You said in your thread you want to remove the rear door panel right?
Look inside the part you grab to close the door. There is a little circle which is a screw cover, pop it out with a flat head and remove the phillips head screw. Pull out the handle part.
Lift up on the back of the window switch holder and disconnect the window switches.
After that you'll have to remove the plastic surround of the actual door handle. The best way to remove it is press down from the top to get it to release from the top. Be gentle the tabs break kind of easily.
If you feel at the bottom of it there is a little opening, just pull towards you and it will pop right out just like the other three doors.
As far as mounting your components I just knocked out the center of the original mounts and screwed my new components in.
Maybe I am confused about what GigEm is talking about.
Old Nov 9, 2006 | 09:48 AM
GigEmAgs07's Avatar
you are right orgullo, i was just sayin that paradox systems how-to for the led mirror install shows how to get the door off. click on this and click on the link right below the pics for installation.
http://www.paradox-systems.com/produ...roducts_id=122 steps 1-8 show how to get the front doors off. The rears come off the same way, just with a few less connectors to disconnect. hth
ef9
Sep 29, 2015 11:29 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
carid
Sep 17, 2015 05:00 AM
