Coil problem or something else?
Old Mar 8, 2006 | 07:23 AM
acMAX's Avatar
Hi all,
So my TCS, ABS, SLIP & SES lights are all on at this point. I'll probably be at autozone tomorrow night to pull the codes but I just recently read a thread (that had an awesome write up..props to bigfatty) on how to identify and replace the bad coil and in that thread it said that if all the aforementioned MIL's are on, it pretty much indicates that you have a bad coil.
Funny thing is the car seems to be fine with no rough idle.
Also, I was told by a shop in Brooklyn (who has yet to even see my car) that all those lights usually indicates that it is a battery or alternator problem.
Is there any validity to this statement?
Old Mar 8, 2006 | 07:42 AM
MAXRB8's Avatar
Doubt it's coils, sounds more like Alternator/charging system problem.
Old Mar 8, 2006 | 07:57 AM
ZeRo MaX's Avatar
I had a similar problem but now all the lights are gone except the SES (reading O2 sensor problem P0160)... it happened when i change spark plugs because I was having odd idling problems. Now my car is in the shop getting the IACV replaced.. gonna cost me around 400$ to get that thing replaced! =(
Old Mar 8, 2006 | 09:48 AM
acMAX's Avatar
what can I do to find out if it's my alternator?
Old Nov 6, 2006 | 02:43 PM
jungleb's Avatar
bump, got the same issues
Old Nov 6, 2006 | 02:50 PM
AceofSpds's Avatar
wat
get a haynes manual im shure it has something about it in there
Old Nov 6, 2006 | 02:54 PM
OC guy's Avatar
2002 maxima se
can anyone tell me what is TB and how we clean that part in our 5th gen?
heard of MAF but dont know what TB stand for throttle body or something?
Old Nov 6, 2006 | 04:45 PM
5thgenmaxima's Avatar
Go to autozone and pull the codes...
Maybe I missed something, but this is pretty off topic to this thread.
and yes TB= throttle body. It is located at the end of your air intake system. (The plastic part) When you press on the pedal it opens your throttle plate located inside the housing (body)
Old Nov 9, 2006 | 09:53 AM
super6's Avatar
well check the codes first! doubt its the coils unless thats what the codes are. i see ur in SI, try the pep boys on forrest av they should check em for free.
PH98I30
20
Mar 25, 2020 03:44 PM
Mar 12, 2020 12:06 AM
gustavison
Oct 4, 2015 06:50 PM
ballerchris510
Sep 11, 2015 05:29 PM
slowlifer
Sep 8, 2015 05:53 AM
