Negative battery cable replacement question
Old Nov 11, 2006 | 03:25 PM
geenowalker's Avatar
Hey,
Just replaced the front left headlight socket and figured that I would replace the negative cable that has been pretty beat up. Stupid queston, I disconnected the battery cable from the engine and it is clamped up on its way back to the battery. Are these clamps just to hold the cable in place, or is there a connector feed for some other electrical component. When I got the new cable from autozone, there is a pig tail connector at the clamp. What is this for. I am totally stock with no engine or electrical upgrades. Kindly keep all boos to a dull roar.
Thanks for the help
gene
2000 SE
Black
148776 miles
Old Nov 15, 2006 | 09:13 AM
I would really appreciate if someone could shed a little light. Is the negative battery cable just from the batter terminal to the engine block, or does it connect somewhere else as well.
thanks
g
Old Nov 15, 2006 | 12:25 PM
SilverGLE's Avatar
I'm watching you, boy...
From what I understand, it's connected to the engine and grounded to the chassis under the battery tray itself. I'd take a look and let you know, but it's raining at the moment. See if you can dig up some of the threads on the "Big 3." Those should have some photos of the battery and grounds.
Old Nov 15, 2006 | 02:19 PM
n3985's Avatar
大陆弟弟
Ya, the cable is grounded to the block, and the chassis right behind the battery, then to the post.
Old Nov 16, 2006 | 05:47 PM
djfrestyl's Avatar
Suspension Yoda
Just follow the wire and take note what it connects to...?
Old Nov 16, 2006 | 06:29 PM
SilverGLE's Avatar
^ That's what I'd do. Good luck!
Old Nov 20, 2006 | 06:20 PM
Finally got the damn thing out and found out that it is connected to the chassis. DOH. The pic shows the connection to the chasis that SilverGLE and n3982 above refer to (thanks). I figure to connect the pigtail on the new cable to this ground.
Thanks for the help.
Balkins
Feb 1, 2016 12:45 AM
schmellyfart
Sep 25, 2015 04:47 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
doobadoo
Aug 15, 2015 06:43 PM
