Grinding Noise
Old Nov 14, 2006 | 09:30 AM
A33 VQ30DEK's Avatar
Grinding Noise
I just got my car worked on last week. I had the axle and axle seal replaced. This grinding noise didn't come up till yesterday and i had it worked on last week. When i drive the car in the morning when it's still a bit cold, there is this grinding noise, but when i let go of the gas it goes away. When the car is all warmed up it goes away also.
can someone help me out?
Old Nov 14, 2006 | 10:16 AM
Maxfli's Avatar
Does the grinding vary with road speed or engine speed? Auto or 5sp? Is it low pitched or high pitched. There may be something rubbing that got moved or is loose from the axle and axle seal replacement last week.
Need more info.
Old Nov 14, 2006 | 02:29 PM
steven88's Avatar
Need A Light?
you need to be more specific...too vague
Old Nov 14, 2006 | 02:31 PM
MaxBoost925's Avatar
Drug Money
I had a similar problem, now it's gotten so bad my tranny leaks fluid.
1) could be the internal bearings in the tranny.
2) could be your bearings in the spindles.
hope that helps.
Old Nov 14, 2006 | 02:57 PM
coool awesome.. i need a new tranny.
i'll wait till it breaks.
Old Nov 14, 2006 | 07:42 PM
irish44j's Avatar
retired moderator
hate to state the obvious, but start with the easy things first:
make sure that your pads aren't low, and that the dust shield isn't rubbing the back of the rotor....
Old Nov 14, 2006 | 08:40 PM
yeah it might be the brakes.
But i just had them changed about 3 months ago. But maybe with my driving who knows. i'm going to tear down the suspension tonight and see what it is.
it's not the transmission or the axle from what i heard from people, so yeah
Old Nov 15, 2006 | 01:10 AM
well it's not the brakes. I checked it tonight. The pads are still quite meaty. WTH could it BE?!
Now the sound is worse. It does it 24/7.
Old Nov 15, 2006 | 01:12 AM
Drug Money
how about the brake dust metal cover?
Old Nov 15, 2006 | 02:30 PM
hmmm ok so i found out the problem. I was missing a washer between the bracket and caliper. The caliper was rubbing against the rotor.
Old Nov 15, 2006 | 03:46 PM
Larrio Motors's Avatar
Boss Chen Industries
Old Nov 15, 2006 | 04:26 PM
AllBlackMax's Avatar
aka The Doom Ship
My problem was a wheel bearing. The dealership replaced the bearing and all is well.
Old Nov 17, 2006 | 05:45 PM
NisTech's Avatar
Just go back and say that since you dd the axle it started making this noise. They'll either tell you what the problem is no charge or fix something if they ****ed up. However not much could go wrong.
Is it a grrr around 30-40 k? -bearing. But axle slides through bearing.
So go back anything can go wrong. It won't kill you.
Old Nov 18, 2006 | 05:49 PM
irish44j's Avatar
retired moderator
look a few posts up....he already solved teh problem
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
