Installed EBC Rotors...weird noise.
Old Nov 15, 2006 | 10:53 PM
Shogunsc4's Avatar
My buddy installed these high-end EBC slotted/dippled rotors along with new OEM pads a few months ago. And now I notice this weird noise when driving (not from braking). I hear this hiss/light taps when I drive and the noise spped varies according to car speed. When I go faster at like >55mph it turns into faster light tapping noise similar to playing cards hitting the spokes on the rim. When driven slow...it is more like a slower continuous hiss hiss hiss.....It gets more noticable when driven next to a curb or wall from the echoes. The noise comes from the front wheel area. My buddy is quite knowledgable and he told me that it is just normal wind noise from these slotted/dippled rotors. Anyone experienced the same noise?
Old Nov 16, 2006 | 12:47 AM
whazzzzuup's Avatar
Check to see if the brake dust shields are touching the spinning rotor.
Old Nov 16, 2006 | 06:07 AM
Teufelhunden's Avatar
could be the wheel bearings.
Old Nov 16, 2006 | 07:53 AM
foodmanry's Avatar
Da Roller Coaster!
The hissing is normal. The tapping...hmmm that's a new one. Check to see if anything is loose, or if you have contact somewhere you shouldn't.
Tapping may be the brake hardware hitting your rim. I mean hardware as in the brackets you put on the pads for vibration dampening and to relief the pad off the rotor.
Old Nov 16, 2006 | 11:52 PM
Shogunsc4's Avatar
a better description of the noise (when driving/ not braking) is more like crickets' churping at nighttime. It gets quite noticable when windows are rolled down and driven next to a curb.
Old Nov 17, 2006 | 05:20 AM
Trurida18's Avatar
is it more like quick scraping noise
Old Nov 17, 2006 | 12:12 PM
Shogunsc4's Avatar
yes...it is that quick scraping noise.
Old Nov 17, 2006 | 12:16 PM
irish44j's Avatar
retired moderator
dust shield touching rotors at bottom edge....
Old Nov 17, 2006 | 01:40 PM
maximamass's Avatar
Could also be those tabs that are on the caliper clips that are used to pull the pad away from the rotor. Those make that noise when they arent clipped into the pad tabs
Old Nov 17, 2006 | 07:05 PM
Shogunsc4's Avatar
took the car to me buddy to get it checked..he found out that the pad is slightly touching the rotor so he ended up sanding down the edges of the pads. The noise is now reduced by half but still exist. He told me that it is normal for slotted rotors.
Irish, I have a question. Wouldn't the noise be a constant grind if the dust shield is touching the rotor? He check the caliper clips and it was the cause.
02PearlSE
Feb 1, 2016 12:37 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
lrb6805
Sep 17, 2015 04:49 PM
