Chewing sound while starting car...
Old Nov 16, 2006 | 04:23 PM
DarkYDK's Avatar
Hey guys. I have an odd thing happening to my car. I searched and couldn't find anything about it. Sometimes, when starting my car, it makes a horrible chewing sound. The starter engages, begins turning over the engine and then slows down as if the battery is dying. But, I had the battery replaced recently.
It does this randomly, I cannot attribute this to anything. Plus, when this happens the car BARELY starts. But after it does, everything is ok. One time I heard an odd knocking sound when this was happening.
What can this be? What should I do?
Thanks a lot!
PS. Forgot to add that I had the starter replaced last summer when it was sticking.
Old Nov 16, 2006 | 05:11 PM
00MaxSE's Avatar
Pointy Elbows
"Chewing" sound?
Maybe the starter or alternator?
Old Nov 16, 2006 | 05:16 PM
DarkYDK's Avatar
Oh, now that you mentioned this... I forgot to mention that I had the starter replaced last summer. The sound is odd. Not exactly "chewing." It is as if the car is bogging down sort of sound. As if there is not enough juice in the battery to start the car.
It starts turning over and then just slows down, almost grinding to a halt. Then it's as if it overcomes some barrier and starts the engine.
Old Nov 16, 2006 | 05:42 PM
Squirrel82's Avatar
sounds like the starter......it did that to me where the only way to start it was to get underneath the car and smack the starter with a hammer until I replaced it
Old Nov 16, 2006 | 08:21 PM
darrelfsu's Avatar
Starter. Mine became progressively worst to the point where it never turned over again. Had the starter replaced and its like new again!
Old Nov 17, 2006 | 07:06 AM
DarkYDK's Avatar
Yea, this seems to be the most logical solution. But I just had the started replaced last summer. I mean... this sux if it went bad so quickly...
BTW, I checked battery and alternator and they are working.
Old Nov 17, 2006 | 04:41 PM
NisTech's Avatar
replace your starter. Sounds like the pinnion shaft is not retracting once it starts the motor and then instead of it retracting the shaft it is still engaged bogging your engine. Your battery is fine it's just the engine bogging making you think it's got no power. So sticky pinion shaft.
Have them inspect the ring gear on the flywheel as well. I am thinking parts replacement warranty is good for a year so even labour if you had it done there. If you do it yourself make sure you disconnect negative terminal first.
Old Nov 18, 2006 | 04:17 PM
DarkYDK's Avatar
Alright, thanks you guys. I am gonna take off the intake and see what's up.
DJLAX152
May 4, 2021 11:46 AM
97_GXE
Sep 15, 2015 06:47 AM
TheMafia
Sep 4, 2015 08:26 AM
