AE Pedals Installed
Old Jun 30, 2001 | 08:40 PM
jashick's Avatar
Installed AE pedals today.
Had to replace the entire accelerator assembly but
surprisingly, it was very simple... just two nuts and a plastic grommet - 15 mins. The brake and clutch pedal covers were a beeyatch though - 20 mins each.
Old Jun 30, 2001 | 09:17 PM
maximaman69's Avatar
Any tips to pass on? I'm wanting to do the same thing to my car.
Old Jun 30, 2001 | 09:21 PM
Scooter's Avatar
Let the pads warm up
After struggling with the brake pad cover,
I let it warm up on the dash for a few minutes
and it was much easier to work with.
Old Jun 30, 2001 | 09:33 PM
blackY2Kmax's Avatar
Besides scooter's tip, you can also spary the pad with WD40. After about 30 minutes of struggling with my brake pedal, I used WD-40 (thanks Dave Burnette for the tip), soaked the brake pedal pad with it, and it just slid right on. Only thing is to make sure you put a towel on the floor because some WD40 will leak out and if you don't want it on your carpet, this will help.
Time before WD40 - 30 minutes
Time after WD40 - 30 seconds
Now if I can only get my accelerator pedal to work - maybe I should try the WD40 again
Early-Built 2000 Maxima
Old Jun 30, 2001 | 09:43 PM
mdeal's Avatar
SUV owner (blackY2Kmax), you just hack that plate off and be done with it.
Old Jun 30, 2001 | 10:00 PM
Ha ha - aren't you funny. I just gotta get some shox, man! Then you'll have to stop with the jokes!!!
Old Jun 30, 2001 | 10:24 PM
mdeal's Avatar
Perhaps jashick could explain exactly how he replaced the accerlerator pedal assembly. That would be a good FAQ, by the way (note: pics are not necessary).
Old Jun 30, 2001 | 10:56 PM
Dario's Avatar
exactly how much would the AE pedals cost for an Auto????
Old Jun 30, 2001 | 11:19 PM
mdeal's Avatar
The cost is about $60. Check the parts list as a sticky of this forum. The parts list gives a pretty accurate cost.
Old Jul 1, 2001 | 12:33 AM
serin's Avatar
how'd you work the accelerator cable? i heard it's a pain to attach.
Old Jul 1, 2001 | 02:10 PM
jashick's Avatar
Sorry I have no digital camera, hence, no pics.
For the gas pedal assembly...
1) Since space is very limited down there, I suggest removing the panel below the steering wheel. To do this, you probably need to remove the door/carpet plastic trip then for the panel, remove 2 screws on lower side. Then, pull top area (there are 2 plastic snaps and one tab that acts as an alignment guide).
2) On the gas pedal bracket, there are 2 nuts... remove these.
3) On the upper part of the gas lever, there's the throttle cable attached to the gas lever via a white plastic grommet that snaps into a hole on the end of the lever. You'll see the throttle cable with a hexagonal know at the end, black rubber spacer, white grommet... give the cable some slack and carefully pop out the white plastic piece by squeezing the free end and inserting through the hole. Be careful not to damage the plastic piece cuz replacing it looks like a hassle... it looks like it's easily damageable so be careful. The gas pedal is now free to remove.
4) Put new gas pedal by following previous steps in reverse order.
If you decide to hack off the bracket piece and just replace the pedal, I suggest you get some heat shrink because the new pedal will be very loose on the old lever assembly.
Old Jul 1, 2001 | 09:40 PM
serin's Avatar
thanks for the info. i ended up using jb weld on mine.
Old Jul 5, 2001 | 12:17 AM
majatoi's Avatar
good prices on AE Pedals
if you guys want a excellent price on the AE Pedals, try out Dave B, get his price then check out Tustin Nissan at: http://tustinbuick.com/nissan/partsorder.html and click the chat with a live technician button at the top of the page, and talk to scott, tell him you are from maxima.org and you were interesed in ordering those parts, he will give you a better price than Dave B, or at least in my case when I bought them he did. I got AE Sills + AE Pedals (brake / accel) for 90$ all together. Check it out! His name is scott. tell him Mansoor sent ya!
MJ
MaxLife17
Jun 27, 2019 01:37 PM
ef9
Sep 10, 2015 10:35 PM
jcvgn
Sep 10, 2015 08:03 PM
slowlifer
Sep 8, 2015 05:53 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
