New Rotors ...
Old Nov 17, 2006 | 10:04 AM
Mints33's Avatar
New Rotors ...
Anyone use any kind of anti seize compound on the new rotors to prevent the suckers from seizing onto the hub?
Old Nov 17, 2006 | 10:12 AM
n3985's Avatar
大陆弟弟
I just sprayed some lube onto the hub.
Old Nov 17, 2006 | 11:01 AM
Mints33's Avatar
What kinda lube did you use?
Old Nov 17, 2006 | 11:19 AM
n3985's Avatar
大陆弟弟
Silicone which I had laying around, I'm sure brake grease will work well too. I know silicone will eventually rinse off, but the rotor sticking to the hub is just more anger release for me.
Old Nov 17, 2006 | 01:45 PM
maximamass's Avatar
i have never had a rotor freeze to a hub and the fact is all it takes is a few hits from the backside if it ever does.
Old Nov 17, 2006 | 02:30 PM
irish44j's Avatar
retired moderator
just give it a hit or two with a rubber mallet and it will pop off.....
Old Nov 17, 2006 | 04:13 PM
NisTech's Avatar
just clean it off with sandpaper and apply copperslip (most parts stores should carry it. And then also clean the rim till you see silver. That way you don't get vibrations as it will be perfectly seated and that way you'll make your rotors last their normal lifespan without warping. Applying copperslip on the rim as well is recomended so both on hub and the mating surfae to wheel.
However DO NOT EVER apply antiseize on wheel studs. Not only that you will overtorque it unevenly but the nuts could back out too and off falls your wheel
Apr 16, 2020 05:15 AM
Socalstillen
Sep 26, 2015 12:01 PM
beerman1378
Sep 8, 2015 02:19 PM
crazyespn
Sep 3, 2015 01:30 PM
