HELP!! Acceleration gone!!
Old Nov 20, 2006 | 12:54 PM
Ryals's Avatar
SHIFT_this
I don't know what's going on, but recently I changed my battery and now my car doesn't accelerate properly. When I floor it, the rpms go up to like 3500, but the car gains speed extremely slow. It makes this gargling sound during the slow acceleration and only gets to like 20-25mph. Even parked, if I push on the gas it makes that noise. If I easy on the gas it'll gain at normal speed, but its garbage if I floor it. Anyone have this issue or might know what is causing it. I checked my oil. Air filter was kinda dirty but I took it out all together to see if it would gain better with no luck. Can someone help me out please?
Old Nov 20, 2006 | 12:56 PM
SoonerFan's Avatar
Cletus
do you really have an 04 like your profile says?
if so, wrong forum.
Old Nov 20, 2006 | 06:30 PM
Ryals's Avatar
SHIFT_this
Not as helpful as ya'll use to be huh?
if so, wrong forum.
Whats up Sooner? Naw I had a 04, but that has been traded for my G35 Coupe. This question pertains to my 2000 Max.
Old Nov 20, 2006 | 07:24 PM
almoodie's Avatar
Acceleration gone
Sounds like a MAF (mass air flow) sensor problem. It is located in the air intake and measures air flow rate, sends sigmal to ECM (engine control module). If it malfunctions, the engine goes into failsafe mode and will not rev above 2500-3000 rpm. Perhaps it was damaged or disconnected when the battery was replaced. Check engine trouble codes for info.
Old Nov 20, 2006 | 07:29 PM
Ryals's Avatar
SHIFT_this
Thanks, I'll get that checked next I guess. The car hasn't thrown any codes I don't think. No check engine light at least. I hope it's not that cause I'm suppose to drive it back to GA this week. It seems to drive fine as long as I'm not trying to accelerate quickly. If I don't get it fixed I hope it can make it.
Old Nov 21, 2006 | 07:10 AM
alpinestars™'s Avatar
THIS IS...
Your MAF or your coils are bad. If you have a CEL get the codes pulled and post them here. Then we can help your further...
Old Nov 21, 2006 | 07:58 PM
madisonmxma's Avatar
MAF sensor problem
Old Nov 21, 2006 | 09:51 PM
MaximaGT-R's Avatar
I'm a Happy Man!
sounds like coils but also check your MAF sensor.
Old Nov 21, 2006 | 10:07 PM
Jasovanni's Avatar
hey bro, I'm in town, let me know if you need any help. Shoot me an e-mail to jasovanni@hotmail.com.
I vote MAF btw.
J
Old Nov 22, 2006 | 06:14 AM
Ryals's Avatar
SHIFT_this
Pardon my ignorance, but what are the coils? Is there anyway to possibly clean the MAF. I pulled out my air filter and it was pretty filthy. I beat it the dust and dirt out a bit and it seems like it tried to improve. I'm going to put a new AF in today and see if that helps at all first. I really hope its nothing serious because i'm suppose to drive out tomarrow morning.
Old Nov 22, 2006 | 06:19 AM
MaximaGT-R's Avatar
I'm a Happy Man!
before you put the filter on ensure that it is totally dry couple of mouths ago i bought a new filter for my car installed it without checking if its total dry it cost me a new maf sensor
Old Nov 22, 2006 | 08:38 AM
MIXXMAX's Avatar
Coils are located on top of the spark plugs. If you don't have the updated ones, you're better off in replacing them. The original coils that came with the car are prone to go bad and are terrible. Cleaning the Maf won't probably do anything. In fact, I wouldn't even suggest in cleaning it. It's very sensitive and it's possible you might end up ruining it anyway. Replace the coils first and see if the problems go away. If not, buy a new Maf and replace the air filter (genuine Nissan). You'll definitely notice a difference once the Maf is installed. It may also be a good idea to get the ECU updated and flashed with the new Maf. Hope this helps any.
Old Nov 22, 2006 | 08:44 AM
MIXXMAX's Avatar
Actually, it's better if the filter is slightly oiled like the Nissan air filters. It traps more dirt. It's the cheap dry ones that allow more dirt to get through. I see that you have a 2k2. It's known that the 2k2-2k3 Maf's are extremely sensitive as compared to the 2k-2k1's.
Old Nov 22, 2006 | 09:12 AM
SilverGLE's Avatar
I'm watching you, boy...
I had the same gurgling sound a while back... It was a combination of the coils and MAF that was causing that (along with loss of acceleration).
Old Nov 22, 2006 | 10:47 AM
P. Samson's Avatar
If ALL you did was replace the battery then it probably ain't the coils or the MAF. Did you allow driving time for the "relearn". NEVER reconnect battery power and then immediately go for any "power runs". If it's just gutless and is not "missing" then it isn't the coils. A coil or coils that give you off idle performance issues will set a misfire code and the SES light anyway. If you haven't put in some "normal" driving time and cycles then try that first before panicing re the MAF.
Old Nov 22, 2006 | 06:36 PM
Ryals's Avatar
SHIFT_this
All this seems way over my head. I'm going to print this thread up and take the car in and hopefully you guyz insight can direct the Strealership in the right direction.
Old Nov 22, 2006 | 06:38 PM
Ryals's Avatar
SHIFT_this
Just had to say that those wheel look good on your car. I have the same set for sale on ebay, but I think if they don't sell I'll put them on my max, cause my chromes are starting to look bad.
Old Nov 23, 2006 | 01:16 AM
SilverGLE's Avatar
^Thanks for the compliment! Yeah, those 18's really do complement the look of my car... Now if only I could get rid of the wheel gap I don't have... Yeah, I'm not the most meticulous when it comes to cleaning my car, so something low-maintenance is good for me.
Old Nov 23, 2006 | 01:51 AM
clborden's Avatar
The MAF's on the 2000 are notorious for going bad even with out a CEL. Mine went bad, with no CEL, with me just removing it from the car. I put it back in and that was it. Same problem youre having. They are cheap enough so I wouldnt even think of cleaning it, and like previously posted, theyre very sensitive.
Old Nov 24, 2006 | 12:49 PM
cmr1972's Avatar
I think it is great that so many people out there know about the ECU, etc. I would be lost without this site.
Old Nov 24, 2006 | 01:23 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
MAF no doubt about it....
Old May 29, 2007 | 11:47 AM
mmendezm3power's Avatar
Black02Max
How much are Mass Air Flow sensor?
Old May 29, 2007 | 11:54 AM
opanick's Avatar
sounds like the wonderful MAF, for a 2000 it should be under a $100 to fix it
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
Maxxx10
Sep 13, 2015 03:16 PM
jcvgn
Sep 10, 2015 08:03 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
