Is this the brake booster line?
Old Nov 21, 2006 | 10:10 AM
delguiner's Avatar
just wondering if that large-ish hose connected to the big drum is the brake booster line?
Thanks!
Joey
Old Nov 21, 2006 | 10:21 AM
maximaownsyou's Avatar
yes the hose connected to the drum behind the power steering fluid is the brake booster line, sea foam? pcv valve hose is also one you can use if thats what your up to
Old Nov 21, 2006 | 10:35 AM
delguiner's Avatar
ya im gonna run some seafoam through the car. it's got about 130k on it now, and i think it needs a good cleaning. can someone point me to the PCV valve also ( i think it'll clean the throttle body also if i use the pcv valve?)
Old Nov 21, 2006 | 12:27 PM
if you look at your intake the hose does a 90 degree, its behind the intake manifold... one end of the hose is connected to the IM where a little metal nipple stick out (which you wont see unless you take the hose off ) and the other end is connected to the pcv valve, which looks like a plastic hex bolt when the hose is still connected. im not sure how good of an explanation that is but you can always search for pics im sure there are a million already posted...
Old Nov 21, 2006 | 02:32 PM
djfrestyl's Avatar
Suspension Yoda
It's not a bolt for the 2000-2001. The PCV on the 5.0 gen gets pushed in and pops out, rather than screwed in.
Old Nov 21, 2006 | 03:31 PM
ah yes i didnt even look at the year he had lol...
Old Nov 21, 2006 | 07:16 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
thats not power steering fluid. thats brake fluid. power steering is on the pulley side of the motor.
Old Nov 22, 2006 | 04:31 AM
wow yeah.. ... ok i need more sleep
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
MichMaxFan
Sep 30, 2015 09:18 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
