O2 Sensor
Old Nov 28, 2006 | 10:40 AM
HoustonHrdHittr's Avatar
O2 Sensor
I took my car in a few days ago to get the inspection done. After the guy told me I failed he said I had a bad O2 sensor. The fault code he gave me is P0138: O2 Sensor Circuit High Voltage (Bank1 Sensor2). I took my car to Goodyear to get the problem fized and the guy told me if there was a problem with the sensor my SES light would have come on, and that my problem might be with the catalysts converter and sent me to a sketchy looking muffler shop. After a short deliberation I decided not to take my car there. Does anyone know what the problem might be with my car and what i should do about it?
Old Nov 28, 2006 | 10:41 AM
O2 Sensor
I took my car in a few days ago to get the inspection done. After the guy told me I failed he said I had a bad O2 sensor. The fault code he gave me is P0138: O2 Sensor Circuit High Voltage (Bank1 Sensor2). I took my car to Goodyear to get the problem fixed and the guy told me if there was a problem with the sensor my SES light would have come on, and that my problem might be with the catalysts converter and sent me to a sketchy looking muffler shop. After a short deliberation I decided not to take my car there. Does anyone know what the problem might be with my car and what i should do about it?
Old Nov 28, 2006 | 11:10 AM
OC guy's Avatar
2002 maxima se
If that guy was able to pull the P0138 code then why you dont think its not the 02 sensor? or wait for the SES light to come on and then go to autozone pull out the code and replace that sensor. by the way why did you need inspection when there was no CEL?
Old Nov 28, 2006 | 01:05 PM
jkayca's Avatar
I'm almost certain you can have codes stored without the SES light coming on. My SES light was on for a good deal of time. Hooked up a code reader and got the same code you did. I didn't do anything to fix it but a few weeks later the SES light went off. I'm pretty sure the code is still there though. My guess is the on board computer got fed up with me and decided not to bother illuminating the SES light to save on bulb life .
I'll try hooking up my code reader tonight and see if I can get anything. I'll clear them if I do and see if the SES light pops back on. Most likely this will happen. Mechanical problems never fix themselves.
Old Nov 28, 2006 | 02:03 PM
crw7292's Avatar
jkayca is exactly right. Codes can be stored in the computer eventhough your light isnt on.
Old Nov 28, 2006 | 02:09 PM
NmexMAX's Avatar
dot dot dot ...
This thread looks so familair.
Old Nov 28, 2006 | 02:10 PM
NmexMAX's Avatar
dot dot dot ...
I've seen this thread before...
Old Nov 28, 2006 | 02:33 PM
707SE's Avatar
Uh, Deja-Vu?
Old Nov 28, 2006 | 07:01 PM
Puppetmaster's Avatar
Threads merged....
Old Nov 28, 2006 | 07:13 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Puppetmaster
Threads merged....
Now I look like a double posting re.. Rightfully so
Old Nov 29, 2006 | 06:38 AM
jkayca's Avatar
Quick update on my experiment. I checked out my codes last night. While P0138 (02 sensor) is gone I still have the pesky P0440 (Evap) code stored. So yes, you can still have codes and not have an SES light. It probably depends on the seriousness of the problem. P0440 is not serious. It just means lower milage. Anyway, I cleared the code. Still haven't got an SES light but I haven't driven much.
Old Nov 29, 2006 | 07:22 AM
707SE's Avatar
that is a passive aggressive statement, not necessarily referring to yourself, no?
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
