Advancing base timing :D
Old Nov 30, 2006 | 07:43 PM
Larrio Motors's Avatar
Boss Chen Industries
Whelp, I finally did it and without the help of a dealer or consult-II
I found that my Autoenginuity ODB-II program has a neat manufacturer specific upgrade, which in Nissans allows factory only functions such as idle target adjustment, timing adjustment, and idle air re-learn (and monitoring of practically all the ECU readings). The tool paid for itself over time as i've used it on many vehicles.
So after driving around for a year looking at my stupid Blitz R-VIT meter read 15 degrees base timing everyday, I bought the upgrade and 5 minutes later...
Then I did the idle air re-learn (although the car didn't react different after the timing adjustment)
Just thought i'd share For anyone that wants to know what the tool can do:
Nissans (functions depend on year and model)
http://www.autoenginuity.com/Nissan-...tems-List.html
Other cars
http://www.autoenginuity.com/products-software.html
Oh btw, the clock time is earlier on the idle air because I was just testing to see if it worked first before trying the ignition timing.
Old Nov 30, 2006 | 09:00 PM
irish44j's Avatar
retired moderator
interesting....
Old Nov 30, 2006 | 09:59 PM
foodmanry's Avatar
Da Roller Coaster!
Hmmm...interesting, so when can we try that on my Max?
Old Nov 30, 2006 | 11:30 PM
A33 VQ30DEK's Avatar
soo larry.. can i go to LA and you do that to my car?
Old Dec 1, 2006 | 01:55 AM
Hoooper
did you try going higher? maybe you can go higher with that thing and see where you can get to
Old Dec 1, 2006 | 06:10 AM
zero2sixtyZ's Avatar
You embarrass me.
Definitely interested and looking to buy this sometime... next year. Doh.
Old Dec 1, 2006 | 06:55 AM
vinny's Avatar
how much is the whole program and what device are you using it with and how much is that device
Old Dec 1, 2006 | 07:02 AM
NmexMAX's Avatar
dot dot dot ...
> you
Old Dec 1, 2006 | 07:36 AM
You check out the price from the link I posted in the 1st post. The price is determined by which system you want and options.
A33: yea, I can do it on your car when you come down. Gotta hook up a past customer
Foodmanry: we can do it the next time we meet up.
Hoooper: just like the Consult-II, you can also advance base timing permanently +2 or -2 degrees. Originally at 15 degrees, +2 correction = 17 degree base timing.
Old Dec 1, 2006 | 07:45 AM
NmexMAX's Avatar
dot dot dot ...
What's the sampling rate?
Old Dec 1, 2006 | 08:10 AM
You embarrass me.
Quick question for my friend that owns a Spec-V, can this program edit the Rev Limiter?
Old Dec 1, 2006 | 08:27 AM
LA02MAX's Avatar
uprev cipher has the same features. Very cool
Old Dec 1, 2006 | 09:23 AM
I don't even think the consult-II can alter the rev-limiter on a Spec-V. It may require some sort of reflash from a company such as Technosquare
The sampling rate is unknown. All it says is 1ms logging accuracy. Its not super great when datalogging, but it gets the job done. Sometimes you pick up random numbers that have to be manually deleted in the excel spreadsheet. It doesn't sample too well during throttle blips in idle (but I like to think that's because my car revs very fast with the lightweight stuff )
Old Dec 1, 2006 | 09:27 AM
NmexMAX's Avatar
dot dot dot ...
Did you get my email?
Old Dec 1, 2006 | 12:52 PM
replied....
Old Dec 1, 2006 | 03:16 PM
stormbringer03's Avatar
OK why do you advance timming
Old Dec 1, 2006 | 03:35 PM
google is your friend
http://se-r.net/engine/about_timing.html
Old Dec 1, 2006 | 04:27 PM
Nomad's Avatar
Difference almost un noticeable. All it does IMO is just makes VQ smoother.
Old Dec 1, 2006 | 06:05 PM
reyrey's Avatar
Did you do this with the ignition on only or does the engine need to be running while you adjust timing
Old Dec 1, 2006 | 11:13 PM
foodmanry's Avatar
Da Roller Coaster!
Personally...based on my experience with my 5th gen I've seen that advancing the timing actually helps with gas mileage. When I had my timing at 17* I saw about 25MPG city and highway with an auto tranny. Now after setting it back to stock at 15* I'm getting about 20 to 21 MPG city/highway. I did notice when I had it at 17* my plugs would burn out faster because of the leanness.
As far as performance I really didn't notice much....only reason I want to go back to 17* is for the MPG.
Old Dec 1, 2006 | 11:37 PM
Engine needs to be on and warmed up, otherwise the procedure won't work
Old Dec 2, 2006 | 03:38 PM
nismology's Avatar
Just for everyone's info, the timing isn't advance passed 2300 RPM when using this method.
Old Dec 2, 2006 | 05:45 PM
Hoooper
my question was can you get it to go more than two degrees?
Old Dec 2, 2006 | 11:38 PM
You can advance it +2 or -2 degrees, just like the consult-II. In short, NO.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
vybz05
Dec 10, 2015 07:38 PM
Starrider
Sep 17, 2015 07:26 AM
305head
Aug 26, 2015 09:03 PM
billrNM
Aug 22, 2015 03:38 PM
