In-cabin Microfilter
Old Jul 1, 2001 | 07:38 PM
arnap
My '01 Max is fitted with in-cabin microfilter but nowhere in the manual does it tell me when this is so I can change it when necessary. Anyone out there know about it?
Old Jul 1, 2001 | 08:03 PM
AdamK's Avatar
Old Jul 1, 2001 | 08:15 PM
bry2kse's Avatar
I believe it's accessed through behind the glovebox.
Go to: http://www.courtesyparts.com/ and look for the filter.. they have directions listed on the site.
Old Jul 1, 2001 | 08:16 PM
AdamK's Avatar
sorry maxima.org is )$(&*)($&)$( up again, well you change every 7500 miles or half year, instructions to install/replace can be found:
<img src=http://www.courtesyparts.com/onlinestore/graphics/00000002/a33_incabinfilter_instr01.gif>
Old Jul 1, 2001 | 08:24 PM
AdamK's Avatar
http://www.courtesyparts.com/onlines...er_instr01.gif
Old Jul 6, 2001 | 04:33 PM
drusting's Avatar
Re: Microfilters
Having recently installed these, here's my .02:
The filters are located behind the glovebox. The instructions from Courtesy help, but it can be a little difficult because you need to remove the glovebox and the lower dashboard in order to access the filters.
A couple tips:
- If you can get a extra set of hands to help you, do it. It's an awkward area to work in while holding up the lower dash.
- Very easy to lose the screws that secure the dash! They can fall between the interior molding gaps, which is basically a blakc hole from whence nothing returns. :-) Use a magnetic screwdriver if possible.
- There are clips that hold the upper right section of the lower dash in place. They have a habit of popping off; make sure you don't lose them.
I thought it would be easy and it turned out to be an adventure. Still, it is worth it, as you can smell/feel the difference (or lack thereof).
-David
fangorn
Nov 19, 2004 02:28 PM
ARVY
Jan 5, 2004 07:13 PM
issa3032
Nov 9, 2003 05:32 PM
GregP
Sep 14, 2003 03:27 PM
