Driver Door Sag
Old Dec 5, 2006 | 10:41 AM
Ollie's Avatar
Driver Door Sag
My door sags..... When I go to close it it rubs the bottom and bumps up. It's a small sag. I can actually move the door up and down a little.
Is there a place to tighten that up? I looked but couldn't figure it out - or do I have to pull of the door panel?
Thanks,
Ollie
Old Dec 5, 2006 | 11:24 AM
JohnWEngle's Avatar
Normally....door sag is caused by worn hinges. Off the top of my head I don't recall what the hinges look like on Nissan's. I've seen hinges that just have pins, which get worn, or some hinges have brass bushings which get worn out. Both types usually suffer due to lack of lubrication. Either type requires removal of the door (a two/three man job) and replacement of the bushings, pins or entire hinge, depending on design of the hinge.
You can check for worn hinges by opening the door and then picking up the door from the bottom. If it's worn, you should be able to move the door up and down, without moving the car. It takes a little practice to tell the difference between moving the door and moving the car. Doors are heavy, even on little cars like Sentra's, so it takes a bit of effort to move the door up and down. On really worn out hinges, you can actually get the door to make a clunking noise while lifting it up and down.
There's no "adjustment" for sag per se. You might be able to adjust the hinges to compensate, but I don't recommend it. Again, doors are heavy - and loosening the hinges and trying to move the door around isn't a one man job. Nor is it easy. And it's quite prone to trial and error.
If the hinges are worn, I'd suggest a trip to a reliable body shop and get an estimate. Typically, it's only the drivers door that wears out, as it's used the most. Depending on the hinge style, the parts will be a few dollars to quite a bit if the entire hinge has to be replaced (and thus will need to be painted to match). The rest will be labor. They should be able to do the work in a day or less.
Good luck!
Old Dec 5, 2006 | 11:39 AM
zero2sixtyZ's Avatar
You embarrass me.
I have the same problem, I guess I need to take it to a body shop. Wish there was an adjustment, but thanks for the insight JohnW!
Old Dec 5, 2006 | 11:56 AM
Memphis2k1's Avatar
Hey guys... this .org member has some info from the NOOB's thread.
http://forums.maxima.org/showthread....93#post5380893
I'm having the same problem as you guys are. Haven't really took it into a body shop yet. I guess I'm waiting to hear some more results.
Old Dec 5, 2006 | 12:38 PM
Ollie's Avatar
Thanks guys -
I now say 'F' it....let it sag. I've spent close to a grand on the thing this past two weeks.
Old Dec 5, 2006 | 12:39 PM
Ollie's Avatar
Hey - you been to that JJ Cigaros up in Fargo?
Old Dec 5, 2006 | 01:46 PM
MerlotMax's Avatar
The pins are not replaceable in the Max. The hinge assm. would have to be replaced, they come black from the dealer and are fairly reasonably priced. Worst part could be the cost for painting and installation.
jsmith24
Feb 1, 2016 12:35 AM
JoshG
51
Sep 21, 2015 10:41 PM
95naSTA
Sep 21, 2015 06:50 PM
lkiller123
Sep 21, 2015 03:00 AM
ajahearn
Sep 19, 2015 03:03 PM
