tranny slipping????? need input please
Old Dec 8, 2006 | 09:55 AM
serin's Avatar
i have a 2000 maxima se automatic with about 130,000 miles. i am the original owner and have had tranny flushes annually, so about every 25,000 miles.
recently i hear the engine briefly revving hi going from 1 to 2 gear. above that, i don't know cuz of road noise.
is that what's called tranny slip? is that normal for a auto? if so, what can i do to fix it? is it as simple as changing the fluids again, or do i have to have it rebuilt?
i tried searching the forum, but most people seem to focus on the fluids. besides which, i'm not even sure if what i've got is tranny slip.
please advise.
thanks.
Old Dec 8, 2006 | 01:01 PM
foodmanry's Avatar
Da Roller Coaster!
Sounds like the TCM or solenoids if its only from first to second. Research it further on here. I don't think those parts are abnormally expensive.
Old Dec 13, 2006 | 04:16 PM
Dave Hardy's Avatar
Sorry not to start a different topic for this, but the board won't let me. Gotta love spammers eh? Anyway, my mom drives a 2000 Maxima GXE with an automatic. Check Engine came on and I told her to have the parts store pull the code and it is P1605, which is a communication line for the auto tranny. I looked in the FAQ, but a lot of the links were broken for TSB's, so I'm not sure if this is part of the typical tranny problems or not.
Can anybody give some insight or point me in the right direction?
Old Dec 13, 2006 | 06:35 PM
BLUEMAX01SE's Avatar
Dammit Serin, you got hi-jacked huh?
Old Dec 13, 2006 | 06:43 PM
serin's Avatar
sumtin like it.
Old Dec 13, 2006 | 06:58 PM
SoonerFan's Avatar
Cletus
http://maxima.theowensfamily.com/tsb/NTB00-039a.pdf
Old Dec 15, 2006 | 11:35 AM
maxottawa's Avatar
hi guys sorry to go off topic but i cant post either but i to have 2000 maxima gle auto and well my tranny has blown for the second time in 8 month's and the both lost reverse and 1st and second it sounds like it want's to shift but it wont and the new tranny has only 70,000km on it and sprayed fluid all over the place so i had it checked and no lines were broken but this is pissing me off cause ijust had the complete car painted (350z) copper and dropped. and a nismo cold air intake put in now it needs a new tranny so any help would be great thanks maxott
Old Dec 15, 2006 | 05:31 PM
mist max2000's Avatar
holy hijackin,.. ok well to the OP.. my only answer for you would be to try a new MAF,.. i would bet anything that is your problem,.. based on what you say,.. because the MAF wont throw codes and slipping will be a big issue from a bad MAF,.. and it will rev funny in between gears ect ect,.. i was skeptical myself at first but it turned out to be the best 100 bucks i spent on the car so far,.. i bet alot of peolpe on here would agree
Old Dec 23, 2006 | 03:20 PM
sair's Avatar
So i see there is a bulletin, i am wondering would nissan cover the tranny....if it just got out of warrenty...my warrenty expired aug 31...but km still not up...just time...
Old Dec 23, 2006 | 03:44 PM
5thgenmaxima's Avatar
Sair, you are way out of warranty by time. They probably will not cover it.
maxottawahi How can we help you?? Sounds like either the rebuild shop didn't do a good job or you are to hard on the car. I don't think anyone here can explain how to rebuild a trans if that's what you are asking. Most shops offer a 12/12 warranty, you should check your paper work.
To the OP, I beleive there is another bulletin for a reflash for a 1-2 slip @ 1/2 throttle for different affected vins. If you need to replace the solenoid, tell the place that does the service to check for shavings when they pull the trans pan, if shavings come out you will need more than just solenoids.
Also warranty labor is 1.4 hours. When calling to get a price to have this done make sure they don't jack the labor up on you. Out of warranty labor is probably no more than 2.1/2.2 hours. (Some shops will jack up the time and bid the job out at 3-4 hours because it sounds complicated.)
James92SE
142
Jan 2, 2024 09:23 AM
gigabyte
Jan 6, 2017 06:05 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
catalinvint
Sep 16, 2015 07:48 PM
