RPM's
Old Jul 2, 2001 | 01:09 PM
damon41978's Avatar
For those who have a 2001 maxima se and stick:
how many rpm's are you revving at when goin 70 mph?
Old Jul 2, 2001 | 01:13 PM
djmaxski's Avatar
In which gear? 3rd, 4th, or 5th? If you mean 5th, I think its about 2800... With the others, I can find out later...
Old Jul 2, 2001 | 01:15 PM
damon41978's Avatar
thanx. i meant 5th gear. i was just wondering becuz i always thought that manual trannies saved on more gas, so if my manual revs at 2800 @70 and my friend's is at ~2400 then his gas mileage is better, no?
Old Jul 2, 2001 | 01:20 PM
djmaxski's Avatar
Ok. Normally 5th gear is for saving gas... However, in the Maxima it seems to be geared to go, especially in the 5sp - an auto runs lower RPMs in overdrive than a 5sp in 5th.
As for fuel mileage -- I guess technically his mileage could be better? I imagine it has to do with the type/make of the gear and the gear ratios in the transmission. However, if his is auto I think he gets worse mileage?
Old Jul 2, 2001 | 01:39 PM
2001SE's Avatar
manual transmissions get better gas milage then auto transmissions. When i drive 80 in my auto 2001 i get about 2700-2800 rpm
Old Jul 2, 2001 | 01:44 PM
damon41978's Avatar
when i go 80 in my manual, i'm at about 3100 rpm's. so wouldn't that mean that if we were goin for a stretch, then i would have to get gas sooner than u would?
Old Jul 2, 2001 | 02:11 PM
2001SE's Avatar
i think the 5sp is more economical in the city rathre then the highway, but to tell you the truth i dont understand this either, 5sp are suppose to be more economical
Old Jul 2, 2001 | 03:10 PM
punkdork's Avatar
Probably due to less drivetrain loss.
Old Jul 2, 2001 | 03:37 PM
y2kse's Avatar
i think the 5sp is more economical in the city rather then the highway . . .
That is correct. Take a look at your estimated gas mileage figures. The figures for city driving are higher for an auto than a manual while the figures for highway driving are higher for a manual than an automatic. And you've already alluded to the reason. The reason is gearing.
Old Jul 2, 2001 | 05:50 PM
Green_2's Avatar
5spd = direct drive. Automagic = torque converter. More efficient to be in direct drive. That means that an automagic with the same gear ratio as a 5spd will output less speed at the wheel because of looses at the torque converter (until it reaches lockup).
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
slowlifer
Sep 8, 2015 05:53 AM
